Question about Boating
I have a 2002 ox66 Yamaha 2 stroke 250 hp std rotation outboard. The propshaft snapped off. The fluid is clean and remaining shaft spins freely. Can i remove the two flange screws and carrier and pull out shaft or do i have to remove just the shift shaft and not driveshaft?
    Sniper:
  • 53 Answers
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Posted on Nov 18, 2009
Testimonial: "Thanks i will try."
Hello I have a 2004yamaha f15ELHC outboard motor GOOD BATTERY IN NEUTRAL PUSH STAT BUTTON and nothing no clicking
Likely a connection issue. Remove, CLEAN and replace all connections. Tighten properly. Could also be a bad starter relay.
Aug 26, 2017 | Clymer Marine Maintenance and Repair...
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Jan 27, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
Sep 29, 2013 | Clymer Marine Maintenance and Repair...
Outboard 115 yamaha misfiring at low revs
Unscrew the 4 idle mixture screws 1/2 turn 1 at the time till sneezing stops...
Clean your carburettors
Oct 31, 2012 | Clymer Marine Maintenance and Repair...
Boating Logo
1,003 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
