Question about ViewSonic Graphic VG2021m LCD Monitor
Resolution problem - Viewsonic VG2021m monitor
Hi, I have the Viewsonic VG2021m monitor which I have been using for about a year. The native resolution is 1400x1050 which I have been using this whole time and have a Nvidia graphics card. It has worked perfectly fine at 1400x1050 for that whole year but now it is screwed up and my resolution has gone down to and won't go any higher than 1024x768?? we have tried re-installing the driver and such but no luck. Really do not want it stuck at 1024x768 when 1400x1050 was working absolutely great before! any way to fix this ??? thankyou.
How do i get a sharper picture please its a viewsonic vg2021m had it given to me i dont know what to do thanks
check the nature resolution of this LCD. It is 1400 x 1050 resolution.
You need the LCD driver from viewsonic web site. Go download and install.
Make sure your graphics card driver is latest one so can auto detect the LCD res. as well.
Good day.
Jan 03, 2011 | ViewSonic Graphic VG2021m LCD Monitor
Hello, I ordered a Viewsonic VG2021m monitor a while ago, and recently, the monitor shows nothing but black when plugged in. All cables on it have been checked, and my computer acknowledges it is there,...
This is 2006 model year, more likely to have bad caps problem in the power supply, look for caps with leaking/bulging tops first, also look to see if you do have 12~18vdc feeding the inverter circuits.
This your power supply/backlight inverter board:
http://www.shopjimmy.com/power-supply-unit-dac-12m033-af-from-viewsonic-vg2021m.htm
Learn about bad caps and failed monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | ViewSonic VG2021m LCD Monitor
The windows 7 is not recognizing the monitor VA721
May I ask what you mean by the windows does not recognized the monitor? You are not getting picture or you cannot set the correct native resolution (that is the best setting for best picture and aspect ratio)?
Native resolution for this monitor is 1280 x 1024 @60Hz.
And here is the common problem with VA721: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Mar 31, 2010 | ViewSonic VA721 17" LCD Monitor
ViewSonic Optiquest Q7b 17" LCD Monitor has a fuzzy picture
LCD monitor needs to be fed with native resolution from the PC video out, this monitor native resolution is 1280x1024 @60Hz, try that setting to see if it helps before opening up the monitor to look for failed components.
Mar 29, 2010 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Viewsonic vg2021m monitor goes blank.
the probelm u are having mostlickly the backlight is out on your monitrer. thy CAN be replaced but with all the time it takes and money to do them i sugjest just getting a new moniter.
Dec 31, 2009 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonic VG2021m monitor without installation software
try using the FN "function key" and you should have a button at the top that looks like and LCD press it while holding the FN button
Dec 16, 2009 | ViewSonic VG2021m LCD Monitor
Viewsonic monitor VG2021m won't awaken
I understand the vg2021m has a 3 year warranty. Phone number for Product Support is (800) 688-6688. Give 'em a call and see if they won't fix it for free or some nominal charge. (OK! So this is the cowards way out.)
Orval
Oct 05, 2008 | ViewSonic Graphic VG2021m LCD Monitor
Resolution problem of viewsonic VG2021m as the second monitor of thinkpad t61p
Go into the NVidia control panel, create a custom resolution (for the ViewSonic VG2021m, you want 1400x1050, 60Hz), and test it.  When the test asks you if it looks ok and you click "yes", it *still* is not activated-- it is simply added as one of the resolutions available for the monitor, and goes back to the same setting you had before... so it looks like it didn't work.  But then, if you go under "Change resolution", you'll see your new setting is available there.  Choose it, and you are good.
It's working for me, on my T61.
Dan
Jul 02, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
ViewSonic Graphic VG2021m LCD Monitor Logo
308 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
