Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
CARRIER AIRCONDITIONING HEATING/COOLING
I have a padlock symbol flashing on my master unit, i am unable to operate my system help!!!
    Problem Solver:
  • 13 Answers
Need to check the condensor fan. If the fan quit working this could lock out the unit so the compressor does not over heat.
Posted on Nov 15, 2009
The unit keeps flashing
By unit, do you mean the thermostat? And if so, do you mean the whole face is flashing, or just a heat or cool symbol? And if your talking about the heating/cooling unit, are you talking about a flash on the board?
A thermostat face that is flashing is usually batteries.
A symbol that is flashing on a thermostat indicates a call and is in a delay. There will be a 5 minute delay on calls if the call has been short cycled, powered off and on, etc.
If the symbol continues to flash for an extended amount of time, then the problem is in the furnace, air handler, etc.
If the system is working, but flashing, then it could be the programming of the thermostat.
Dec 02, 2013 | Honeywell Heating & Cooling
Ever since I had my Unit model 40QxA10-7/38QPa10-7 SERIAL No 745099/o13363 installed in JAN. 2008 I paid a fortune for service and regas every Year. It was supplied by First Choise Airconditioning Again...
an HVAC cooling system is a seal system. it should only need refrigerant added if the level is low. AND if the level is low, there is a leak. Your service company should locate and repair the leak. My system is 10 years only and have never added refrigerant. If only the outside unit was replaced, the indoor unit may be the issue. good luck.
Aug 05, 2017 | Carrier Heating & Cooling
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
I got an Airwell ducted air conditioner unit with 4 outlet model: GC24RCC-S and Remove controller 4 and PCB unit is Storm 2. When turned on, the green operation led of the display controller unit is...
Check the unit that's located outside .You need to open it to get to the control board ,there you will see a couple of buss fuses. Check to see if fuses are fine. Do this with the power OFF on disconnect
May 19, 2017 | Heating & Cooling
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Hi I have a Fujitsu Split system. As of recently it has started to mysteriously started to flick over from heating to cooling on its own. It is a 2.5KW unit and heats rather well. ALl of a sudden you hear...
Yes i can! The mode of operation (MASTER CONTROL)has been set to AUTO instead of HEAT. Easy mistake and very simple to fix. Press the MASTER CONTROL button until HEAT is display on the LCD.
I hope that this helps
I take the time to answer you questions so please rate me
Thankyou
Mat
Jul 13, 2009 | Fujitsu 18R1 Air Conditioner
Mitsubishi PAR-F27MEA AC controller icon meanings
hi.welcome to the mitsubishi worl of airconditioning.thay are great units to have.ok let me explane this for you.
the sun is for heat mode
the snow flake is for cooling mode
rain droplet is for dehumifiy the air if its a humid day.i hope this helps you.you have to choose the modes on the remote for the unit.then the unit will do the mode you choose on the day.
Jun 09, 2009 | Heating & Cooling
I have a Carrier infinity model 38tdb037-3. The outside unit will not come on. the control board on the outside unit shows an amber led on status 2.it is a steady constant flash.the error is an apparent...
Have you eliminated the possibility of a high or low pressure error. Sounds to me like it's off on safety. Should have troubleshooting the flash right on the panel. Test your pressure switches for continuity.
Jul 13, 2017 | Carrier Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
80 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
