Question about Iomega ScreenPlay (33359) 60 GB Hard Drive
My Harddisk was playing OK quality of movies. Then I bought an HDMI cable to imporove the Quality of the movie .. but then it still did not work. Then i changed the resolution of the Hard disk from 560p to 1080i and since then .. my hard drive is not showing any of the components such as movie music pictures or anything of that sort. Please help me out guys !!
  • 7 Answers
SOURCE: Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Posted on Aug 26, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: I got this hard drive so I could free space on my
Just because you transferred it to your external hard drive. You will still have the files on your internal HD. You will need to delete the files off your internal HD and they will still be on your External HD. I had to do this with mine and other clients.
Posted on Jan 05, 2010
SOURCE: Cannot add anything to my external hard drive
re-hobrax
also make sure you are in administrator account to make changes
Posted on Feb 19, 2010
  • 79 Answers
SOURCE: My macbook recognizes hard drive
You may need to change the partition map scheme. I imagine it is using the GUID partition and should be the Master Boot Record. The best way to do this is to select the drive in Disk Utility, then choose the Partition tab. Change the Current partition to one, click on the options button, choose Master Boot Record (MBR) then click OK. Then on the format drop-down menu change the format to Free Space, then click Apply and OK. Then the drive is ready to format with FAT32 that your PS3, etc. can recognize. To do this click on the Erase tab, choose FAT32 in the Format drop-down menu, name the drive, click apply and OK. The drive should now work cross-platform on Macs, PCs, and media devices. Please let me know if you have any questions.
Regards,
Gene Gilbert
Posted on Jan 21, 2011
SOURCE: My Sony Bravia doesnt recognize
Check if it formatted in FAT32 and then also check web site :http://esupport.sony.com/docs/imanual/NA/EN/3a-0/usb_uc.html to be sure of folder structure (hierarchal position):
/AVCHD/BDMV/STREAM/00000.MTS/PRIVATE/AVCHD/BDMV/STREAM/00000.MTS
/MP_ROOT/100ANV01/MAHA0001.MP4, Have a good time, David
Posted on Feb 04, 2011
SLOW UNFOCUSING AND BLURY PICTURES ON MY HISENSE TV AND LG HOME THEATER
Single speed between new tv and old player may be causing latency. Double check specs on the newest component and make sure they are upward compatible.
Dec 30, 2014 | LG Audio Players & Recorders
Tip
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to spend approx. $70 for video card and install it. I found "VisionTek Radeon HD 4350" to work fantastic.. Make sure your LCD TV has a HDMI INPUT. If not, you will need a newer TV. All thats needed now is a HDMI CABLE. The cable can be purchased anywhere computers are sold for between approx. $30 to $40. Depending on length. The cables can be found for much less ON-LINE. firefold.com has the cables for approx. $5. and they are the high quality gold plated cables. Now plug the cable into the computer and the TV and then using your tv remote, switch to HDMI and your tv is now a computer monitor. "Note"you may have to make adjustment on computer for display size and quality. My LCD TV is a 46" and the video card described above supports HD full screen. A wireless mouse and key board are a nice feature to add. If you like movies, you can get netflix and stream movies. there are many other sites for streaming and downloading. after doing this with my computer, i dont have a cable bill any more..I hope this tip helps.
on Dec 02, 2009 | Computers & Internet
Why do Netflix movies keep stopping?
It could possibly be a slow internet connection speed. Netflix posted requirements. This is a good site to check your speed. http://www.speedtest.net/ Internet Connection Speed Recommendations Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
HD Video Quality
Movies and TV shows we have available in high definition will play in 720p or better with a fast enough internet connection. To watch Netflix in HD, ensure you have a HD plan, then set your video quality setting to High in the Playback Settings for your account.
Netflix Bandwidth Usage
Higher quality video uses more bandwidth than lower-quality video. If your service provider applies a bandwidth or data cap to your Internet service, you canManage Bandwidth Usage by changing the video quality settings to Low or Medium to consume less data.
Oct 01, 2014 | Netflix
Hi,I have a XP-65DHD RUNCO PLASMA DISPLAY when I want to play a blu-ray movie on 1080p the screen starts flickering so I have to watch the movies on either 1080i or 720p,I really don't know what to do
If you got a blueray player (the hardware) it should have come with a disk with software. If you got the OEM version without, you need to buy your own software. PowerDVD should work. If you are somehow looking to download something to play bluray disks on a PC without an actual bluray player, you need to buy the drive.
Mar 21, 2014 | Runco CW42i 42 in. HDTV-Ready Plasma...
I m not getting clear picture when i m playing online movie on the projector
Hi raj, i think problem is on cable you connect projector to get video signal form your Computer
Get a 10m HDMI cable along with setupbox which has HDMI out..
else switch to component video at least..if you want to do justice to the prj ohyeah.gif
Roughly on an average projector cost of watching 1hr of video comes to around Rs 20-30.. don't waste that with poor quality cables.
Good luck ! if you think your problem solved don't forget to rate
Dec 31, 2010 | Computers & Internet
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
Ps3 hdmi to tvmonitor dmi
You mean HDMI to DVI right?
You need a cable hdmi----->dvi, there are a lots of them, you will find them in any good tv/audio store or on the net. Buy one of good quality, you wont regret it, the differens betwin a good quality and a cheap one is huge
Good luck
Dec 08, 2008 | Acer Computers & Internet
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Iomega ScreenPlay (33359) 60 GB Hard Drive Logo
20 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
