Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
I cant remove the write protection of my kingston
How i cant remove the write protection of my kingston dtm/512
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 28, 2010
    Novelist:
  • 111 Answers
Kingston is one of the biggest manufacturers of computer memory cards. They also have a large market share of the flash memoryi cant remove the write protection of my kingston - mag-glass_10x10.gif sector, including USB flash drives, SD cards and micro SD cards. Flash memory cards like the micro SD can be locked in Write Protect mode, which prevents you or someone else from accidentally deleting or copying over important data
  1. tep 1 Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it.
  2. Step 2 Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3.
  3. Step 3 Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4.
  4. Step 4 Delete and repartition the micro SD card using Windows XPmag-glass_10x10.gif. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Posted on Nov 15, 2009
  • Kingston Master
  • 27,725 Answers
Click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Posted on Feb 05, 2012
My usb doesnt have a drive when i look to its properties. i cant open it either... it doesnt show on my computer. what should i do?
your pc & kingston flash driver already affected by virus ,you cannot maintain the folder options because autorun.exe is runnning, you should go to another pc ,where that pc switch off the autorun from >run>gpedit.msc> administrative templates>system>d click on turn off autoplay>ennable >d arrow>select >select all drivers>ok .go tools>folder options>view>check on all hidden files> check off hide extention........ & hide protected ........
Then after use your affected kinkstone flash driver
.Now you can see the many hidden file ,drag it and delete it or format the flash driver but your main pc should format and install the os again.
Nov 11, 2010 | Kingston (SDCZ2-512-A10-KT)...
Kingston datatraveler 512 MB is write protected. there is no switch.i cant format del data
Well u cannot do nothing than to kindly replace it. If u r able to get it working, it'll tell u same thing after sometime. 100%sure
Feb 07, 2010 | Kingston Technologies 512MB DataTraveler I...
Can't remove a file from usb drive! (how to remove a protection?)
Hi DuuuX,
This is an indication that the file system has become corupted. All you can do is contact Kingston for a warranty replacement.
Kingston Tech Support
Nov 23, 2008 | Kingston (SDCZ2-512-A10-KT)...
How to remove write protection in flash card
which model ?
micro sd card do not have any write protection
Jun 28, 2008 | Kingston (SDCZ2-512-A10-KT)...
My kingston usb flash disk undergoing write protected physicaly
its not jumber ,its a looks like a switch..
First try to see is there any lock in your pen drive and see if its not locking it, you will see a switch which locks the pen drive at one side and unlocks it when you slide that switch to other side ,some drives comes with that option to protect it ..but if it is not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Mar 01, 2008 | Kingston (SDCZ2-512-A10-KT)...
My kingston flash disk physicaly write protected
Hi
In the side of the drive there is small white switch . slide the switch in the opposite side,then it will be ok
Jyo
Kingston DTM 2GB
hello roc0380,
it seems that the Kingston 2GB DTM is fully compatible with Microsoft Vista. So I don't think you'll have to upgrade the Migo software on the device. If you connect the device to your Vista machine and there are any malfunctions, try downloading the most current version of the Migo software at http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DT_mini
Hope this was helpful information
Kind regards and thank you for using the FixYa services
Feb 11, 2008 | Televison & Video
Computers & Internet Logo
975 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
