Question about Samsung Jet S8000 Cell Phone
Hi I can connect to my router no problem, but when I try to access the internett it will not connect to anythinh. It just tries and tries so allthoug connected to router, it seems i cant "surf" so is there a firewall issue or something other in the wifi setting i need to correct. I see that the proxy option is empty, should I insert something there. Generally there are many questions lke protocol ? proxy ? index-id ? what should be inserted ?
How to reset my router and what will be happen is theirs anything will need a pass word or what please help me thank you
Hello Sir,
1. How:
Find a pen or a paperclip or somthing very smal then
To reset your router you need go to the router find a litle hole and press it in hold for 10 sek then it will be reset to factory settings, if this doesn't work try holding it a little longer.
2. What happens:
passwords are removed, user settings are removed (like if a user is blocked from the nett he will now have access) DHCP might get started or stoped, both might be a problem bt this is depeding on your router and internett provider aso.
3. Fixing problems(If you have problems):
when you reset your internett router you might need to call your service provider (the phone/internett company) then you need to tell them that you reset your modem and the internett doesn't work. they will sett the DHCP settings to how it should be.
Sep 03, 2011 | Computers & Internet
I can't connect to youtube. I get this page that just say 404 not found
404 - page not found
1. st check that you didnt mispell the URL: http://www.youtube.com (this happens alot)
2. check your internett conection
3. if your internett is down check if some one else has internett problems (an other computer)
4. If everyting else fails, restart computer, stil problem: restart router.
5. call the phone /internet company
On the company web this page might be blocked if so you can go around on pages like:
http://youtubeproxy.org/ then type the address it will be (alot slower)
Aug 24, 2011 | Computers & Internet
When i try to go to youtube i keep geting a error 404 report is there anyway to fix that? i did a disk cleanp an defragmenter but didn help
Aug 23, 2011 | Computers & Internet
My Alienware M14X, running Windows 7, cannot connect successfully to the Internet through my Linksys Rangeplus WRT110 wireless router. It can pick and and technically connect to the router's signal,...
try reseting the router (pressing the button the size of the tip of a pen)
Do not try this if this is the main internet router (unless you dont have any choice).
It might need to be reset from Server side (your phone/internett company).
There might be some setings lost and you need to set a new password (the old one back)
Aug 23, 2011 | Linksys RangePlus WRT100 Wireless Router
I am re-configuring my Belkin wireless router and ip adr 192.168.2.1 is not accessable. I have connected my PC directly to the router and have internett access.
make sure your pc has an ip address in the 192.168.2.xxx range while you're configuring the modem (set a static one TEMPORARILY) to get access to modem. Don't expect Internet to work during this temporary situation for router configuration. be sure you change your ip (and DNS) settings back to "obtain automatically." Restart computer before trying to get on Internet again.
BTW, what are you trying to accomplish--overall; why are you reconfiguring your router? Will it stay on this network?
Oct 28, 2010 | Computers & Internet
I turn the PC on and connect the wireless
This occurs with the vast majority of routers. Either upgrading the firmware of the router by going to the manufacturer's website, or getting a new router usually solves the problem.
Dec 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Wireless internett porblem acer 4810T
This may be a problem with your ISP and not your computer. You say the same thing happens when you are hard wired to the Internet via a cable. Get a friend to come over with a laptop and try it on your cable. If it still has problems then it is the ISP and not the computer.
Call your ISP and let them know their service is not working. It could also be the router that is not providing a reliable signal. If that router is supplied by your ISP, have them replace it.
Sep 09, 2009 | Acer Computers & Internet
Please help me get my wireless settin
  1. I assume that you mean you cannot see your wireless network in the "Available Networks" list?
  2. Yes, there will be a switch on the laptop to enable/disable wireless.
  3. Is your router set to broadcast SSID? If it isn't then you won't see it in the list of available networks.
Aug 30, 2009 | Acer Aspire 3000 Notebook
Cant get the Linksys to find the Optus DSL network
do you have security enabled on the wireless router?
if so, disable to security and see if you can connect.
if it works, check if you set the router security to use WPA2- it is possible that your laptop/wireless card doesn't support it- try to use WPA instead
Aug 02, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Was working ok, now cannot get online using belkin modem-router. Says I am connected to my network, "signal strength excellent" but no wireless connection. Using the Belkin Modem router I am unable to...
please try to reset your router.
on the back of the router there is a little hole where you can insert a pen or a paperclip. hold it pressed in for 30 seconds and then release.
wait 10 minutes and try to connect to internett again (after connecting to the wireless net ofc)
May 28, 2009 | Computers & Internet
Samsung Jet S8000  Cell Phone Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
