Question about Krups 574 Power Xtreme VI Premium Work Top Blender
Krups model 574 blender doesnt work.
Hi, the blender doesnt work. When you press any button the motor or mechanisms don't work or move. When you press the pulse button, the light does come on. The plastic gear and motor both turn freely by hand. Any clue as to the problem? Thanks
5 Suggested Answers
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
SOURCE: I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Posted on Mar 28, 2009
SOURCE: Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Posted on Aug 11, 2010
tcaprista215
SOURCE: How can I open akrups gpa3 blender.It does not work only 3 years
Its a bit hard to remove it, but eventually it will come off.
Mine is a Krups GPA1 and the on/power button has two hard clips (each one with a large spring easy to work with) that need to be pulled out of their sockets.
Posted on Sep 26, 2011
O RING 574
There are 4 Krups 574 models, the seal shows as obsolete for 2x of them and still current for the other 2x
Part number for the seal that is current is MS 0974091
Apr 19, 2014 | Krups 574 Power Xtreme VI Premium Work Top...
Blender malfunction
can you hear the motor working.
Jul 14, 2008 | Krups Blenders
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
Part number and price
You have to contact the manufacturer for that kind of information. We do not have part numbers or prices. We do not sell any parts.
Feb 23, 2014 | Krups 574 Power Xtreme VI Premium Work Top...
The body of the blender is held together by three cross head screws two at the base which are clearly visable and a third which is concealed by the pulse on/off switch which you need to prise off to reveal - small spring to rear to catch! Our blender went totally dead due to a blown internal fuse which I have now replaced and hey presto we are back in action.
Mar 10, 2010 | Krups Blenders
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
I have i blend 5 speed and i turn it on and nothing happens
COMMON sorry to say , the problem is with the control , there is no fix except to return it . what i have been telling people is untill appliaces start getting better and not just this PRETTY JUNK from china go find a goodwill store and get a nice 20 year old blender and you will have it for years . or if you have the bucks buy a VITA-MIX there good but expensive good luck
Jan 15, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Ed,
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
Krups 574 Power Xtreme VI Premium Work Top Blender Logo
65 people viewed this question
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
