Question about Ovens
Neff FD7903 Oven Drop down front door no longer fully closes & is getting worse - are the hinges adjustable?
    Scholar:
  • 62 Answers
Hi.
Yes it sound like your hinges are worn. They are not adjustable but can be replaced. If you send me the model no (usually starts with a U) then I may be able to either give you the part number or order them for you. They are quite easy to replace.
Regards
Aardvark Repairs
Posted on Nov 15, 2009
  • 378 Answers
I'm afraid not.
"Drooping" doors are very common on Neff ovens - I've had to replace a couple of sets - and seem very sensitive to things being placed on the door whilst in the open position, e.g. roasting tins whilst basting a bird/joint.
Replacement hinges are available - just Google your model number and the sponsored results will include several companies who can supply them - not cheap, but much less than a replacement oven.
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
The door no longer closes correctly leaving a gap at the top. When open it is no longer horizontal but falls to a downward slant
It sounds to me that the oven door hinges need to be replaced, especially if it is a drop down door
They need replacing as a pair.
There is no povision made for adjustment on hinges.
Hope this helps you.
Dec 08, 2009 | Miele H340-2 BP Pyrolytic Electric Single...
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Thanks
Nov 09, 2009 | Bosch Ovens
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
My neff built in oven door does not close fully
You probably need to replace the oven door hinges, as the springs are weak.
Jul 16, 2008 | Neff B1421 Electric Single Oven
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
384 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
