Desk fan broken due to melted component
I have a desk fan, it broke, when i opened it i saw a component put in between the live wire and a switch mechanism, i have connected the two wires that was connected to the device and it works fine, i am just concerned about the effects that this change will have later on.
A description of the component follows: It is round steel cylinder with a coper strip on the outside, on the copper strip lays two copper connectors that is pressed to the cylinder which is connected to the wires that goes to live and the switching mechanism in turn.
  • 379 Answers
I believe what youre describing is a thermal fuse.
Normal fuses (like the one in the plug) protect against too much current being drawn by a faulty device, which is the most common type of fault.
Thermal fuses protect against the temperature within an enclosure going above a certain level, which can occour even though the current being drawn by the device is within the rating of the normal fuse.
Thermal fuses are an additional level of protection for the user of a device that has a tendancy to overheat without drawing enough current to blow the normal fuse. They also provide protection to the device itself where overheating may be caused by a condition outside it's normal operating envelope such as something has jammed the fan blades. Most fans use shaded pole motors, a type of motor that when stalled (jammed) doesnt draw excessive curent but does overheat.
It's your call as to whether you continue to use it without repalcing the thermal fuse, but so long as you dont leave it unattended, I doubt it will be a problem.
Posted on Nov 15, 2009
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Computer will not turn on.checked power cord and power supply. Both are good. HELP.
    Are you sure the button is working? If you're savvy enough, and since you've been able to test the other components, take the button apart and hot wire that computer by tapping the wires together. It's worked for me in the past.
    Here's how to fix it long term!
    How to fix broken power switch on my computer
    Oct 03, 2015 | Computers & Internet
    Disassemble a dyson desk fan
    Hi there, it's Jack at Dyson.
    We would strongly advise against dismantling your Dyson Air Multiplier desk fan any further than is shown in the User guide, as this could cause damage to the internal component and electronics. Additionally, it can also void your Dyson warranty if this is currently valid.
    If you're having any difficulty with your Dyson fan, please contact us directly so we can provide further assistance. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    We'll look forward to speaking with you.
    Oct 18, 2014 | Dyson Desk Fan
    Taking apart
    Question about Brookstone Desk Fans: Slim Personal Desk Fan
    Taking apart I took mine apart by removing the small screws that hold it together. my top fan cage was broken and loose. I glued it back together and the next day I just reassembled it and it works fine.. just look at what you are doing and dont FORCE anything common sense should allow you to do this... I am a retired auto mechanic 80+ years old and it did not give me any trouble until the e-clip jumped off, but I found it and all is well.. the screws are shiny and the case is black, so take them all out and lay in a pattern so you can reverse the pieces for reassembly..
    Feb 19, 2013 | Brookstone Desk Fans: Slim Personal Desk...
    Thermo fan will not work on 1996 klx 650, when engine is running or hot, there is a wire to the sensor and another which is broken, beside it. Should the broken wire be connected to something? If so, what?...
    Hello;
    Let's figure this out. Broken or otherwise disconnected wires usually cause an open circuit preventing adequate current to a componant. Two wire switches act as light switches do. they either close or open a circuit.In this case, the warning lamp or fan relay is ativated when the temp rises. Cold, the circuit is open/ broken preventing any controlled componant from activating.
    First check for any power/voltageat the disconnected wire and the connected wire. Which ever wire that is powered is the supply wire. The one without is your controlled componant wire. Touch the two wires together, bypassing the switch. The fan should come on and turn off when disconnected again. Ignition switch needs to be on.Because of the load the fan pulls, a relay is between the fan and switch.
    The switch closes powering the relay, then relay close contacts closing a secondary circuit which in turn permits power to the fan. The fan circuit is powered by the battery and controlled only by the relay.
    Yuup, two circuits. Switching and fan drive circuits. Yes, Hook the wire back onto the switch after testing as outlined here. Good Luck and remember to always verify power (fusec ondition). _Ned_
    Apr 03, 2011 | kawasaki KLX 650 R Motorcycles
    Push button desk lamp switch --the button broke off
    Add in-line switch to cord, available at home center.
    http://www.uniteduniversal.com/images/product/000_0143.jpg
    Or put lamp on a remote control
    Example of remote control that I use:
    http://www.amazon.com/Woods-13568-Wireless-Control-3-Outlet/dp/B001Q9EFUU
    http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
    Add a comment with your experience so others with same-similar problem can benefit.
    Also take advantage of fixya expert assistance live.
    For a price, expert works with you while you work on lamp or any do-it-yourself project.
    Fixya is always less expensive than a service call.
    Mar 21, 2011 | Leviton MFG 041-05226-00I ELECTRICAL...
    ORBIT FAN DOESNT ROTATE AND OUR DESK FAN MOTOR OVERHEAT WHAT IS THE BEST WAY I CAN DO,, THANKS!!!!!!!!!
    If thisis two fans, the first one check the starter capacitor to the motor. it canbe weak or defective or the coil winding of the motor is open. check the switched power tothe coils.
    The second motor can get hot due to friction or loose bush/bearings or faulty capacitors or faulty windings.you must check all these one by one.
    Aug 31, 2010 | Vacuums
    Mi copiadora sharp AR5125 tiene codigo U6
    code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
    Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
    Chill mat
    i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
    right?
    if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
    Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
     Grubhead
    Grubhead
