Question about Zenith IQC50H95W 50" Rear Projection Television
Zenith iqc50h95 50 in rear proj
Turn it on , you hear the power supply click and then a pulsing , chirping sound
i bought from repair shop in fl.it had a new power supply and new convergence chips thanks to power surge! its been fine for 2 years and then poof! as it is chirping the red led near the ( def power supp ) connector
is pulsing bright to dim in synch with the chirp. it sounds just like the pulse of
tv powering up but instead of one chirp and a picture, i get no picture and
chirp,chirp,chirp,chirp! the guy in fl says to replace the convergence chips,
another shop says it sounds like the high voltage side of the power supp.
help!
    Novelist:
    Champion:
  • 232 Answers
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Posted on Jan 09, 2008
Hi, my zenith won't turn on at all. My friend gave it to me and said it needs a convergence chip. When I press the power button I hear a series of seven small chips and nothing else. I work on computers...
U have tools like a soldering iron,desoldering pump or desoldering braid and solders?U know how to do basic soldering?The tv convergence board require replacing 2 STK convergence ICS and some or all it resistors too,to solved this chirping sound problems.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u $300-350 for parts and labors.
Oct 14, 2010 | Zenith R40W46 40" Rear Projection...
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
No Picture or Sound and chirping from rear
Most likely there are defective capacitors in the power supply. The chirping you are hearing is the attemt to fire up the supply. The cold may have been enough to cause the caps that were on the verge of failing to completely fail. This should be a simple repair for any shop. If you wish to attempt the repair yourself, let me know and I'll try to get you mode details on the likely defective parts.
Dan
Feb 13, 2009 | Philips 51PW9363 51" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60" Phillips HDTV Model # 60pp9202/17f chirps, no pic or sound.
This is a common problem with the Philips Tv sets. Get a repair kit from www.TvRepairKits.com.
Jan 11, 2008 | Philips 60PP9202 60" Rear Projection...
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
IQC50H94W Zenith Projection tv
check the flyback/hv-spliter sounds like it could be your problem also check horizontal ic
Jan 23, 2007 | Zenith IQC50H95W 50" Rear Projection...
Chirping & no power
It sure does sound familiar! The churping is most likly the power supply starting up and detecting an overload condidtion and shutting down. Or the power supply is trying to start up and cant but keeps retrying to. Unless you know how to trouble shoot SMPS Please leave this one to the pros.In a case like this One or maybe twp boards will mosy likly need replaceing or repaired if the tech you call in is decent. Good Luck
Jul 25, 2006 | Zenith IQB50M90W 50" Rear Projection...
No Pic or Sound
It sounds like a defect in the horizontal drive or HI voltage circuit. Could be the Horizontal output transistor , and /or the flyback transformer, a short in the scan derived power supply on the output of the flyback transformer. If your not aware of the HI VOLTAGE issues and have soldering experience you should seek a pro to assist ya in this repair. If you do have the experience, get a schematic and start with the hi voltage circuit. Good Luck
Jun 18, 2006 | Zenith IQC50H94W 50" Rear Projection...
Zenith IQC50H95W 50" Rear Projection Television Logo
259 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
