The hard drive doesn't answer. The green light is flickering. No icon for the hard drive on the desktop.
    Genius:
  • 1,274 Answers
Sounds like the hdd is dying or the enclosure is dying, i would recommend turning off the pc and adding the drive as a slave on the sata/pata cable and rebooting to see if it sees it. You can also boot up a live cd of linux and attempt to access the drive that way, download any live cd, i reccomend kanotix for something so small.
Posted on Nov 15, 2009
My lacie external hard drive doesn't show up on my desktop the light just flicker
When it eventually will, check the disk (all terms may vary, depending of your version of Windows) :
Right-click the icon of the disk, then click "properties".
In the "Properties" window, select the "Tools" tab, and click "Check now". Check both checkboxes, and run.
This should fix the access problems on your drive.
Aug 28, 2014 | LaCie External USB 2.0 500GB 7200 RPM 500...
Rocstor icon disappears from desktop and light is half orange/green
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
HP Pavilion a 1020n desktop - green power supply light on back flickers \ pulses when power cord is in place, but system will not respond when the power on button is pressed.
just remove the ATX cable from the motherboard (24 pins connector coming from the power supply),the power cable to the HDD and the and the dvd drive and then connect the power and chekc whether the light stays on or flicker ,if it flickers then the power supply is Bad if not then there is a probelm with the motherboard
Mar 01, 2011 | HP Pavilion a1020n (PS583AA) PC Desktop
My firelight external hard drive's case was a bit damaged when traveling, but still worked fine. Until today, it is no longer showing up on my desktop as an icon and I can't find it under "My Computer"...
This sound as though the controller board in the case has disconnected from the hard drive.
1. if you can disassemble the case carefully and reconnect the controller board this may retrieve the hard drive. If not then the controller board to the hard drive is damaged and a new case is needed to connect the hard drive and for the pc to read the usb port you connect it to.
I hope this helps. Have a great day!
Oct 04, 2010 | SmartDisk FireLite 40 GB Hard Drive
Drive was working fine a few days ago... but now when connected to pc and power supply, the green light on the front just flickers and the pc can't locate the drive. lead connecting drive to pc is fine,...
Three possibilities:
1. bad data-cable between computer and external drive;
2. the USB-to-disk-drive adapter inside the casing has failed;
3. the disk-drive inside the casing has failed.
Advice:
1. try a different cable;
2./3. disassemble the drive, and extract the disk-drive, and try to connect it as a "slave" drive in a desktop computer, to see if the drive itself is OK.
Jan 16, 2010 | Western Digital My Book Essential Edition...
I have a Dell Inspiron 6000 laptop computer and I'm experiencing a problem with the orange battery light flickering continuouslyl; though the green battery light is displayed. Thank you
I think you may be referring to the green power light and the orange hard drive activity light.you should have a power icon located on the bottom bar on the desktop near the clock that indicates battery power.
May 14, 2009 | Dell Inspiron 6000 Notebook
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
No green light
If this is a new drive you will have to fdisk it and format it. It should have came with a cd driver disk to run before you plug it in. It will help you set everything up.
Dale
Jan 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Medion Desktop won't boot. Flickering power light????
I agree with the hard drive solution. I would check that first.
Dec 25, 2008 | Medion MD-1704 PC Desktop
Cannot open hard drive
have you had this drive long if new then go to the control pannel on the mac and find the Amiistrative Tools open then computer managment open then Disk Mangement then open and find the unallcated drive then properties then partition format partition then go to nxt step then follow till end excepting all defaults as hdd is formated for pc not mac so id is needed to be reconised on mac. close all windows then in my computer you should now see hard drive letter if not turn off drive then return on.
Jun 15, 2007 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
