RIM BlackBerry Storm 9530 Smartphone Logo
Posted on Nov 15, 2009
Having issues converting an unlocked verizon storm to att. New sim, now can receive emails, can't call out or receive calls or texts. Help please
Can i unlock a sprint phone
    1. Unlike Sprint, the SIM slot on Verizon iPhones comes unlocked. Caveats: While you can use SIM-equipped Verizon phones on AT&T, T-Mobile and other GSM carriers, unless the device has roaming GSM radios it won't be able to make phone calls or send texts in the United States.Jul 28, 2014
      Now that it's legal, here's how to unlock your phone on all ...
      https://gigaom.com/2014/07/28/unlock-phone-att-verizon-tmobile-sprint/
    Feedback
  1. How to unlock your Sprint phone or tablet - WhistleOut
    www.whistleout.com/CellPhones/.../how-to-unlock-your-sprint-phone-or...
    Mar 12, 2015 - Home>Cell Phones>Cell Phone Guides>How to unlock your Sprint
2helpful
2answers
How do you download a web browser for Verizon BB9530 now unlocked to AT&T
Hi, let me straight about the meaning of unlocked phone. If your phone already unlocked from verizon network using blackberry storm 9530 unlock code, you can use any sim card on that phone. Which mean you can access data service, internet service or everything else only from your sim card network provider. So if you use an att sim card on your mobile phone, there is no way to download verizon web browser and why you need verizon web browser? Why you just not to use att web browser? If you still insist to download verizon web browser you can replace your att sim card with verizon sim card, then you can download that web browser on your blackberry and what is the point you spend some of your money for blackberry unlock code if you still using verizon sim card?
1helpful
2answers
I can not dowload the att mobile net work browser on my unlocked blackberry storm 2. I am using a att sim card and paying att for unlimited data. How do I download att mobile browser so I can search the...
Hello, make sure your blackberry phone already unlocked using blackberry storm 9530 unlock code. To test your phone already unlocked or not is by replace that original sim card with another sim card from other network provider. If you can't make a call using your new sim card maybe you have wrong blackberry unlock code, which mean your phone not yet unlocked. But if your phone already unlocked you can download att mobile browser by following a certain step from here. I hope it can solve your problem.
2helpful
I bought a blackberry storm 9530 on amazone. Its unlocked because i am in netherlands antilles and can make and receive calls and text messages but i cant browse the web or use BBM. I think Verizon has it...
Seems like your phone network is locked which needs to be unlocked. This can be done through Blackberry unlocking codes with IMEI. You can unlock your Blackberry Storm 9530 from them since they provide trusted and affordable codes to all their clients. i hope this would help.
3answers
Need and unlock code for verizon blackberry storm 9530 to use with att sim card
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
1helpful
I installed an unlock codeon my Verizon Storm 9530, phone is unlocked, have ATT SIM card installed, but when ai try to make a call it gives an error message that reads "CONGESTION". What should I...
Just saw your post and wanted to help anyways so please let me advise you Blackberry unlocking codes with IMEI if you want to unlock your phone with high quality, guaranteed, trusted and CHEAPEST codes. Thanks and good luck :)
3answers
I'm trying to unlock my BB storm 9530,after I type "MEPPD" I enter "MEP2" or "MEPP2" but still I dont get any window to put the unlock code in,any ideas ?!
Before you start, you MUST have an Unauthorized Sim Card inserted. An unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on. 1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see “Code Accepted”
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process “Code Accepted”. You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Verizon Blackberry 9530 unlock?
Go to http://blackberrymep.com and get your unlock code along with instructions to enter it .
4answers
Want to unlock my verizon blackberry storm
Here is what you want http://blackberrymep.com , fast (5minutes), cheap (11.5 usd only), Guaranteed (Tested by me) .
2answers
If you unlock an at&t LG Xenon GR500 can you use it with a tmobile sim card ?
You can, but you may have issues texting, using mms, and internet. T-Mo would have to change the settings on the phone to work with their network for that; they may not do that since it's an ATT phone. Phone calls would work fine though without any changes.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
