Question about Procom MN300TBA Heater
How much to repair a faulty oxygen depletion
How much do you think it will cost to repair a faulty oxygen depletion sensor in a delonghi calor gas heater?
What is P0157 code for 2006 saturn Vue
Bank 2 sensor 2 fault. That would be the downstream oxygen sensor for bank 2.
Aug 03, 2015 | Saturn Cars & Trucks
My gas fireplace shuts off after burning about five minutes - both main burner and pilot shut off.
Most fire place burners have an oxygen depletion sensor on them nowadays. If you can restart it after a while, a few minutes or so, and shuts off, it is probably the oxygen sensor. The owner lights fireplace and shuts the door, and the fire depletes the available oxygen and the fire will start producing copious amounts of CO which is a hazard. Most fireplaces have a fresh air supply available to provide combustion air but needs to be opened for the fireplace to work properly. Check the manufactures recommendation as to the proper installation of the fireplace furnace.
Hope this helps
Feb 05, 2015 | Heating & Cooling
Check engine light is on. code P0140 on 2006 Kia Rio
- Faulty Rear Heated Oxygen Sensor Bank 1
- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
Replacing the Rear Heated Oxygen Sensor Bank 1 usually takes care of the problem.
Oct 13, 2013 | 2006 Kia Rio
P0131 sabb 93 2001 po121 error codes
P0131 - O2 Sensor Circuit Low Voltage Bank 1 Sensor 1 (sensor is before the catalytic converter)
Possible causes- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Front Heated Oxygen Sensor Bank 1
- Exhaust gas leaks
P0132 - O2 Sensor Circuit High Voltage Bank 1 Sensor 1
- Exhaust gas leaks
I am not really sure what is going on here with the same O2 sensor giving these lean and rich codes, if nothing else is apparent and the engine runs well you may have a defective O2 sensor.
Sep 13, 2012 | Saab 9 3 Cars & Trucks
Pcm code po139 eldorado
P0139: O2 Sensor CKT Slow Response (Bank 1 Sensor 2)
- Exhaust gas leaks
Feb 07, 2012 | Cars & Trucks
We have a Rinnai REH-15F-2A natural gas heater (approx 15 yrs old). it has just started going out, it doesn't leak gas. is this something repairable or beyond repair? thanks tameka
Tameka, what you described sounds like the Thermocouple or Thermopile is failing. If your heater is a Flue-less heater, the Oxygen Depletion Sensor (ODS) which is part of the Pilot assembly, may simply need cleaning. Any of the causes I listed are repairable and would require a service technician to do it.
Hope this helped you. Please let me know.
Jul 06, 2011 | Rinnai Heating & Cooling
I have a everdure 6 burner gas heater. its pretty old and works sometimes. the problem is that it take a while to turn on and once it started it just turns its self off with in minutes. this happens...
Your flue-less gas heater may simply need a a good interior cleaning and servicing. From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be clogged with dust, lint etc. The ODS is part of the pilot assembly and constantly reads the oxygen level in the room, when the heater is in use.If the oxygen level drops to 25% the ODS shuts the unit OFF by closing the gas valve. This can occur if the ODS is dirty, because it's falsely reading the oxygen level.
One other thing that can mimic this problem is a faulty Thermocouple. With age, they wear out. It's also a safety feature that controls the gas flow to the pilot.
Everything I have mentioned is repairable. But, if you want to make it a DIY project, it will require some dismantling of the heater cabinet to access everything and replace parts. If the heater is as you say "pretty old", you may want to consider buying a new heater. Sometimes, it's just not worth the time and effort to repair an old heater.
Hope this helped you to troubleshoot and solve the problem.
May 27, 2011 | Heating & Cooling
OBDII SETS CODES P0401, P0171 & P0174 . 1998 Mercury Sable
P0401- Exhaust Gas Recirculation Flow Insufficient Dectected
Possible causes - Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR passage clogged
- Exhaust gas leaks Possible solution - Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Code P0171- Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem P0174- Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem.
Jun 28, 2010 | 1998 Mercury Sable
Heating & Cooling Logo
189 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
