This problem should be removed because:
Problem with Panasonic Projection Televisions
I have a Panasonic ET-LAE700 Replacement Lamp with Blue Haze
I have a Panasonic ET-LAE700 Replacement Lamp for the Panasonic AE700U projection that after less than 200 hours is now showing a blue haze on the right hand side of the screen. Do you know why that is occurring and should the manufacturer replace it? The first lamp lasted about 3 years and 2,000 hours
Suggested Solution (2)
The optical block is most likely causing the problem. It will continue to get worse. Sony may help with the repair since they have had a lot of problems over the years with their optical blocks across many models. On the older sets they usually only help with the parts cost. The average repair cost for a optical block replacement is $1200.00 to $1500.00. So if they help with the parts cost it really brings the cost down. Their customer service number is 1800-222-SONY.
I hope this helps,
Skyassoc
Testimonial: "Tnx for info. Justifying a new tv just got a whole lot easier. Bet it won't be a Sony......"
Sounds like the light engine is going bad...that's why they stopped making these rear projection sets using LCD's. Costs almost as much as a new set! But get a second opinion before trashing it.
Source: little blue dots on screen and large blue haze in upper left corn
My Panasonic LCD projector has
My Panasonic LCD projector has a blinking LAMP light, how do I fix it? Model # PT-AE700U, hasn't ever had an issue before..
I changed the LCD lamp, but there is still a...
I recently changed the lamp on my Zenith E44W46LCD. It had a yellowish haze before I changed the lamp. The tv screen is brighter, but the...
replace lamp flashed today, how long til i lose...
how long after replace lamp warning until i lose picture? model pt-50dl54j
When I removed the projector lamp, the grid/-like
When I removed the projector lamp, the grid/-like prism mirror that the lamp is mounted against has a slight haze to it on the right side....
lamp flashes red and tv
lamp flashes red and tv just shut off
Tips for Helping don099 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
my RCA tv green power button flashes and beeps,...
2004 HD tv large box
samsung dlp tv shutting down
After working well for a number of hours the TV shuts down and restarts then goes through the shut down restart sequence...
TV - Samsung LE32A457C1D White picture
Hi, my TV switches on fine, everything works well except that the picture quality is really white. It looks as though...
P52937sg will not stay on one channel
Person was playing with a light switch hooked to the power for all my entertainment equipment now when I turn the tv on...
Fix-O-Meter
60
60 people viewed this problem
- 0 people are following this problem. Be the first!
Top Panasonic Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
I have the same exact problem. Replaced my bulb 3-4 weeks before, now i have a blue haze in the corner with blue specs. I have always trusted Sony. I am sickened.
