Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Keyboard is not responding it does sometimes then stop again
    Sergeant:
    Champion:
  • 215 Answers
Step 1
  1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Posted on Nov 15, 2009
    Genius:
  • Dell Master
  • 1,274 Answers
The ribbon cable may not be connected all the way, i would try and reinstall the keyboard drivers from support.dell.com
Testimonial: "thank u so much for ur help that was great"
My Samsung r 730 display drivers stop responding and then reset again
Uninstall and reinstall latest drivers from your graphic cards website
Mar 06, 2013 | Computers & Internet
Suddenly yesterday, the "U" key in my laptop has
A single key failure on a portable is almost always a mechanical failure of the keyboard itself. The good thing is keyboards are generally cheap and easy to replace.
You can buy the keyboard here:
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Inspiron+1525+keyboard&_sacat=See-All-Categories
How to replace it here:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
Jul 15, 2011 | Dell Inspiron 1525 Laptop
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
Keyboard not responding to EVERY stroke
MAY BE BECAUSE THE KEYS DON'T COME IN CONTACT WITH THE PLASTIC LAYER IN KEYBOARD OR MAY BE COMPUTER DOESN'T GET CORRECT INPUT SIGNALS
Jan 22, 2009 | Logitech 967437-0403 Keyboard
No audio sound after installing the keyboard software
when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Nov 18, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard's keys sometimes don't respond
It is not a driver it is a keyboard that is having troubles itself unfortunately, you can try to find new one on eBay since that ones printed wires sort of are broken. What happens is that your keyboard pops out a little and disconnects some letters so you need to press in the middle to get it back to work, the same thing was happening to previous one.
Feb 07, 2008 | HP Pavilion dv6000z Notebook
Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Nov 09, 2007 | Logitech Cordless Desktop MX 3000...
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
1,171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
