Question about Saws
I have an elu flip saw that works as atable saw but not as a drop saw is there a wiring diagram so i might trace through the fault
  • ntsikleas Dec 17, 2009
    ihave replaced the wiring but am unsure of the correct wiring as i was not the only one to check it out and suspect that the previous owner may have altered the wiring
    Problem Solver:
  • 14 Answers
There is a cable that runs from in behind the drive belt and around and under to the main switch block . because of the flipping action it can open circuit . youllhave to check it with multi meter . good luck old but good machine.
Posted on Dec 12, 2009
Testimonial: "thanks ill try black and decker"
  • connor1956 Jan 05, 2010
    sorry idont have the wiring plan for the tool but if you contact black& decker they may have it
On the switch there is a little button by the stop switch when you flip over the saw for chop side make sure the base is preessing down the little switch
Posted on Nov 09, 2012
Elu 172. How do I remove flip top and the safety guard to clean?
Hi mate this is in the wrong category but i have an elu flip saw and to remove the guard you take your blade off and guide bush and remove the circlip and the guard pops off but u need to make notes on where the guard return spring fits through a hole on guard so as to replace, and remove the bolt with the screw driver slot in and washer / spacer to detatch the folding arm inside the guard, i will check mine and jog my memory then get back to u,does yours have a duel size bush for different blade diameters / centres. Paul
Sep 19, 2015 | Garden
Elu tgs172 motor stopped running and makes whirring noise and will turn very slowly if the saw blade is turned
Sounds like a worn out bearing.
Instead of the shaft turning concentric with the outer bearing, it roles around in the worn bearing like the wheel of a stunt car going around a loop-de-loop --except the relative sizes are closer so it makes a lot of racket.
That Elu is a cool saw concept. They came out in the 1960's before commodity Miter saws hit the market so big. I've used one before.
I suspect the bearings can be pressed out and replaced. Take the saw to a motor repair shop and you might get them replaced for $15 a bearing. There's one bearing at each end of the motor.
Sep 25, 2014 | Saws
Electrial drawing for a flip over saw model COD2000FLS
Check out the links associated with these images. I suspect it is identical to an ELU
Elu tgs172 Google Search
Sep 24, 2014 | Saws
Elu manual
Elu is taken over by Dewalt. I can't find manual online but try to check on Dewalt band saws. ; you can use Dewalt manuals for reference. Are you cutting metal? I use Haltbar 601 series bi metal blade for cutting steels.
Jun 20, 2014 | Saws
My elu flip saw shorts out when I flip it over from a table saw to the chop saw, it works fine as a table saw
There is a bridge rectifier its a little black round piece in the box of the red green switch that must be replaced i see you have got a gray or bleu ELU not a dw 743 i know this problem that is what i know buy a new rectifier or place 4 diodes 1n4007 in a bridge if you know how to do this to make AC to DC its only for the magnet switch and connect the 4 wires to it .
May 28, 2014 | Dewalt Dw743n 240V 250Mm Combination Saw
Elu tgs saw wont start up flip over
i have no clue what you're talking about
Aug 01, 2012 | E-Machines W3107 (RBW3107) PC Desktop
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
Dewalt DW742 won`t start
These machines have an induction motor and need a capacitor to give it a kick start. Is it humming when you push the button? If so I would check the capacitor and you will probably find the fault there. Otherwise it could be a problem with the table switches. When the table is flipped it pressesd against a button which tgells it which on switch is operational. If something has blown there it would disable both buttons.
Oct 19, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
877 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
