My pioneer dvd player shows change region settings, but resetting buttons not working
  • 537 Answers
SOURCE: Panasonic DVD-LX9 "disc may not be played in your region" error
Try cleaning the lens with a cleaner?
So it only reads music/Audio CDs and won't play DVDs?
Do you get an HO2 or HO7 error? If it is that it might be
the spindle motor.
You might try this website also to reflash the firmware:
http://www.firmwareupdate.us/
Mike
Posted on Nov 09, 2007
  • 86 Answers
SOURCE: Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Posted on Nov 25, 2007
SOURCE: Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Posted on Sep 16, 2008
SOURCE: Proton PD-800 DVD player Region reset
After working on it cleaning etc.., resetting features and searching for a manual, I finally found the orginal manual. Sounds stupid, but the solution is to unplug the unit for a few minutes. The processor needs time to reset.
Picture will resume to default settings.
Posted on Oct 12, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
How to change the Pioneer DV0-C503 DVD player from region one(US) to zero(region free) Thanks !
1) Turn on without any DVD inside.
2) push setup button.
3) go to general tab.
4) set the "Setup menu Mode" to Basic and leave the window that shows "expert" and "basic" options open.
5) press Display to see the actual region number.
6) press CONDITION MEMORY and then the Region number do you want to set.
7) press Display again to verify that the region have been set.
That should be it!
Feb 27, 2011 | Pioneer DV-C503 Multi-disc DVD Player
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
Unlock code region hts5560
Open the Philips HOME SCreen,...
Type on your remote: 13893108520
This will display all of the current settings for your player.
Region_Code: DVD(2) BD(B)
This will not change any settings, but will report your current settings. So it's a reporting function only.
To change your DVD region settings try the following:
Turn on player with no disk inserted
Press "Open/Close" on the remote control
Press 259 on the remote control
After enter the code 13893108520 again on the HOME Screen and the player will show region "0"
Now the buttons on the front of the player do not work anymore.... You will need to go to SETUP and click on RESET FACTORY SETTINGS....
Wait until the player restarts and now you can play all DVD regions..... ;-)
Oct 16, 2010 | Philips Televison & Video
Unlocking zone for samsung dvd-p181
One of these 2 should work.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Aug 04, 2008 | Televison & Video
Brough DVD's from america. Wrong region for Australia. I have a Samsung DVD P181/XSA player. How can I play my dvd's. Is there a way to break the region code on my DVD player?? Thanks Sylvia ...
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 .
OR
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Jul 30, 2008 | Televison & Video
Pioneer dv 323
Zone is the region of your dvd player and what dvds its capable of playing. If you didnt know what you have done then its hard to know what could be wrong, first things first try this .. this is a factory reset that if you did change something important in the home menu it will fix it for you and start the system from the beginning when you first took it out of the box.
hope this helps mate.. if it doesnt email me back on here.
jon
Resetting the system
Use this procedure to reset all system settings
to the factory default.
1 Switch the system into standby.
2 Press and hold the front panel
(stop)
button for about 8 seconds until the
display shows ‘Mem.Clr.?’.
3 Press the front panel play/pause
button.
All the system’s settings are now reset, and
you should see the ‘Let’s Get Started’ screen.
Jun 21, 2008 | Pioneer DCS-323 System
Unlocking DVD - Pioneer DV400 k
Hi Jetix,
If the DVD player is capable of playing other regions, you should be able to change the region setting through the menu section. If there isn't an option to change the region settings in the menu, then your DVD player is not able to play other DVDs from other regions.
Sincerely,
Agent Xiong
May 27, 2008 | Televison & Video
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Sep 08, 2007 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
