Question about Sony VAIO VGP-WKB1 Keyboard
Spacebar key is stuck down on one side. - Sony VAIO VGP-WKB1 Keyboard
    Genius:
  • Sony Master
  • 1,274 Answers
Pop the space key off altogether using a screwdriver or any flat object, make sure the scissor clips that it connects to are not malfunctioning, you can install new clips, but popping it up and reattaching it should fix your problem
Posted on Nov 15, 2009
Spacebar disfunctional
change out the keyboard or turn machine upside down and shake it gently. You may have something stuck under it
Apr 27, 2014 | Microsoft Windows 7 Professional Upgrade...
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
My spacebar wont move on the Brother Charger 11, (nor will the carriage move when I press any key) it seems like the shift key is stuck
The carriage lock may be on. Either on the right or left side of the carriagle (little lever) push or pull up or down.
Nov 02, 2013 | Brother Office Equipment & Supplies
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I have a mac Laptop and the space button on the bottom of the keyboard is stuck down .. can this be fixed?
It is tricky to repair the space bar. It has a plunger in the middle and is held in place by tension clips. The tension clips are what make the spacebar pop back up. Usually one clip comes loose and the other side still bounces. If the spacebar is stuck down with no bounce, I would check to see if there is something wedged under the spacebar. Get a can of compress air and blow under it, hopefully this will release whatever is under there. Only take the spacebar off carefully without jerking it upwards. If it breaks the clip holder at each end, you will need a new KB.
Good Luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 31, 2011 | Apple Computers & Internet
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
SPACEBAR WILL NOT SPACE
Inspect the spacebar paralell guide wire. When depressing the spacebar on the right or left side extreme the spacebar other side should travel down at the same time. If not the spacebar will not actuate the electronic keyswitch under the spacebar. Most likely, the keyswitch is defective and requires replacement.
Oct 12, 2009 | Olympia Mastertype 3 Typewriter
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Spacebar key wont click back on
I find the trick to putting laptop keys back on is to extend the little arms completely up. (it looks like an X from the side) then put a very small screwdriver on at least one side to stop them falling back down, then press the key on firmly but gently. The top of the arms should click into the underside of the key, then you should have its springy-ness back.
Let us know!
Feb 05, 2009 | HP Pavillion ZV6000 Notebook
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
Sony VAIO VGP-WKB1 Keyboard Logo
360 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
