Question about Whirlpool Washing Machines
The rinse and dryer are not functioning. - Whirlpool Washing Machines
    Problem Solver:
  • 6 Answers
Whirlpool ,roper ,kenmore all have direct drive for the spin & agitate cycles the coupler is underneath about center behind the motor. It is a plastic coupling with a flex coupler made of rubber on both sides. Part #1195967 usually run between 12-20 bucks if this doesnt fix it you probably have a bigger problem motor or transmission.
Posted on Nov 15, 2009
Tip
How to Troubleshoot Your Dryer
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Flashlights</span> </li> <li> <span>Screwdriver Sets</span> </li> <li> <span>Flashlights</span> </li></ul> <ol> <li> Make sure the cord is plugged in and that the breaker hasn't tripped.<br /> </li> <li> If drying time is too long, check the vent hose. Keep it as short as possible to lessen drying time.<br /> </li> <li> Remove some of the clothes if they are not drying properly. You may have overloaded the dryer. This problem may also be caused by rinsing the wash in cold water, a leaky door seal or a clogged filter or duct. Check into these problems.<br /> </li> <li> Replace the breaker (or fuse) if the dryer isn't heating up. Also make sure that you are using the heat cycle and not an air cycle.<br /> </li> <li> Look for loose objects inside the drum if the dryer is noisy. If that's not the problem, tighten all of the screws on the exterior panels and make sure the dryer is level. If it's a thumping sound you hear, you may need to replace a roller or drive belt.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
on Jan 04, 2011 | Dryers
Indesit widl 146
Firstly look to check nothing is stuck in the pipes as in coins or wire from bras etc..these will always cause problems for the machines... if this isnt the problem it may be a fuse. Or worst case senario one of the boards needs replacing.
Mar 17, 2014 | Washing Machines
Water will not drain after rinse
The filter or the drain volve may be blocked with the dust particles else the motor is not functioning properly
Dec 22, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
Feb 27, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
ZANUSSI ZWD1471S
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
26 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
