Question about SanDisk Sansa e250 MP3 Player
My sansa e250 won't charge
I plug it into my computer and it turns on but won't recharge! HELP I miss my songs..
  • 2 more comments
  • obwogi Feb 28, 2008
    when i plug my sansa into the computer it turns on but won't charge
  • cutiepie3663 Jul 28, 2008
    well when i plug in my mp3 player it turns on but itll say writing or connecting but it wont charge up.then ill leave it on there for some time and when i come back for it itll say battery low.please help.
  • fatimoose Aug 24, 2008
    i'm having the same problem, it used to charge just fine but now it just turns on but doesn't charge. It's unlocked when I plug it in so I don't know what the deal is. :<
  • pepsilover Sep 07, 2008
    i pluged it in into my computer.
    it turned on and it says connected.
    but it wont charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Posted on Jan 12, 2008
I plug it into my computer and it turns on but won't recharge! HELP me
Posted on Sep 11, 2008
    Novelist:
  • 167 Answers
If your USB port isn't powerful enough it won't be able to charge it. Try to plug your sansa in to a desktop computer (not a laptop)
Sandisk provides "how-to" videos for everything Sansa related
You should check out the sansa community forums, they are very helpful
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
Posted on Jan 09, 2008
4 Suggested Answers
  • 12 Answers
SOURCE: sansa e250...computer will not detect
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
Posted on Jun 10, 2009
  • 6 Answers
SOURCE: how to load songs in sansa e250
Is the cable working?
Posted on Jun 27, 2009
rockitman187
  • 2559 Answers
SOURCE: My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Posted on Jul 30, 2009
Jul 30, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 problem
No sound out put from sansa e250.
there has be firmware updatd in recovery mode & again firm ware updated with the help of sansa updater.. still no sound out put at all..
its confirmed that the headphones are ok...
please help
Oct 11, 2008 | SanDisk Sansa e250 MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Songs Being Deleted!
Your device may be full or close to it.
Try This;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 PLEASE HELP!
The battery has come disconnected from the charging contacts in the back.
Remove the 4 screws, remove the battery from the back and re-insert it.
Best of Luck.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250 won't charge all the way!! Help me!
Sounds like the battery may have come loose in the back, so its not charging.
Take the 4 screws out, remove the battery. The put the battery back in and try charging it.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 getting worse since "upgrade"
Format your player and re-transfer your songs. The best way to format the player is by changing the player to MSC, then connect it to your computer and open My Computer and right-click and format the player remove the quick format then click start. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
Need help quick with sansa e280
try switching your usb mode, do that by going into settings, this might help but im not sure
May 28, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
648 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
