Question about Nokia 6650 Cellular Phone
Nobody can hear me when I call them - I went to the Nokia site for help - it's a waste of time unless it is a common problem or my fault. People I call cannot hear me at all (mobile phones mostly, landlines not yet happening as far as I am aware) - yet if they call me they can hear me. The numbers are o2 yet my wife, also on o2, can hear me (?) The only reason is that the folk I call a lot are o2 users (I am with T-mobile (unfortunately)) It appears the phone either has a problem or has set itself up like this - this appears to have happened after I was on a call while charging teh phone though this may be a coincidence, it's the only possible reason (or incident) at about the time the problem started - I'd prefer not to have to factory reset as the My Nokia s/w is so dumb and has, on a previous occasion, lost all my numbers. This phone can and will start playing music or taking photographs in my shirt posket even though I have locked the keyboard - so it appears not to be very bullet-proof or, should I say, somewhat 'iffy.' Thanks, pma950
  • pma950 Jan 06, 2010
    The phone "died" shortly after, condensation having damaged the internals we found - case closed.
I had fuel pressure checked they said it was good. Told me maybe fuel injector?? Don't. Wanna waste time or money
Nobody wants to waste time or money but diagnostics is a process and not a guessing game.
Most of the time things have to be checked and if nothing is found it seems like a waste of time and money but in reality checking and finding nothing eliminates possible faults so the next stage in the process can be moved to.
A full fuel pressure and delivery test also checks for dribbling or leaking injectors but there are no definite tests checking for spray patterns without removing the injectors for specialist attention.
Mar 06, 2016 | Cars & Trucks
Hilp me gevme my acount in crossfare becouse my acount being hack
When your account is hacked, nobody can help, unless you are a paying costumer, the site can help you. Next time, please chose a difficult to guess, but for you easy to remember password.
Oct 01, 2014 | Computers & Internet
Panasonic ct-32hx42f won't power up
There is a short circuit [with one or more component/s] at its main board. Contact any service technician to get it repaired. The troubleshooting to this kind of fault is really a skilled one. Never switch ON the set until the fault has been recertified. It might make things worse. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2014 | Televison & Video
My transport overheats and spends too much fuel
It sounds to me like some diagnostics needs to be done. Nobody can tell you with any certainty whay is causing your problem without checking the vehicle out and diagnosing the problem, unless you just want to waste time, energy and money trying to GUESS.
May 19, 2012 | 1997 Pontiac Trans Sport
How to replace transmission 1995 nissan quest
get your instructions from the repair guides at autozone.com, instead of wasting your time on sites like this.. because nobody will give you ALL of THAT for free.
Dec 22, 2010 | Nissan Quest Cars & Trucks
I have a vauxhall movano 3300 CDTI will only start with easy start even when hot but it drives great Help.
hmm have to think about this ,has anyone changed the timing belt?? or if its common rail then dealer only to diagnose the fault
Jan 23, 2010 | 2002 Volkswagen Eurovan
I ANT TO LOCK MY KEYPAD WITH PASSWORD AS NOBODY CAN USE MY CELL
u can lock kepad with code by simply going into menu-setting - security - phone lockcode - desired code as follow steps , phone will not blocked with this action unless u forgot the code
even someone enter wrong phone code more than ten times phone will be not accept even correct code that time so u have to wait for 15 odd minutes & re-enter code so i think there is no fear of blocked or locked code unless u forgot it
Feb 15, 2009 | Nokia 3110 Cellular Phone
Nobody can hear me
check that the screws at the bottom of the phone are tight, if there is a slight gap within the circuit board and the microphone this can cause the problem it is a commom fault
Jan 02, 2009 | Nokia 6300 Cellular Phone
Nokia n95
the microphone is probably broke or the hole that goes to'it is stuck with dust
Apr 20, 2008 | Nokia N95 Cellular Phone
Help! If you know anything about fixing nokia 3120's please read
You broke the Microphone curcuit. In most cases where you drop a phone , you will have to replace it as the cost of parts and labor almost alwaays More then a new phone. But see what type of repair your Provider gives?? Good Luck
Apr 21, 2006 | Nokia Handsfree Car Kit For 3100, 3120...
Nokia 6650 Cellular Phone Logo
139 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
