Question about Hotpoint Aquarius WF000 Front Load Washer
Im getting f -05error towards the end of all programmes and cant get it to spin or pump out on a hotpoint aquarius wmf50
  • Hotpoint Master
  • 3,463 Answers
F05 means that the pressure/\water level switch is jammed on full.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove other end of hose onto pump, and check for blockage or obstruction here.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf000 not completing final spin
u should check the drain filter and try to listen to the pump if its working
or the outlet hose might b stuck
May 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
181 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
