Question about Sony I/M CMT-CP1 98 FRENCH Shelf System
Sony cmt-cp1 says no disc when a cd is inserted
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: I have problem with my sony cmt-cp1 model. NO DISC
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
Sony cmt-ne5 cd reads no disc
Then it is time to replace this player the Laser reader is defective or the disk doesn't spin due to a defective drive motor, in most cases they don't even sell parts for these players and they are not repaired unless under warranty.
Jan 23, 2012 | Audio Players & Recorders
My cd player does not play music in order, instead of 123...it skips to 5 than 8 etc.
There's a control under PLAY MODE that selects random play labeled "1 DISC SHUF". Normal play would be "ALBM". Read the manual.
http://www.retrevo.com/support/Sony-CMT-HPX9-manual/id/268dj180/t/2/
Jul 18, 2011 | Sony CMT-HPX9 CD Shelf System
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Thanks and regards
    Stelios
    May 08, 2010 | Sony CMT-CP11 CD Shelf System
    Micro hi fi component system sony cmt-ne5 / ne3 I
    Hello
    Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
    Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
    Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
    It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
    Jan 21, 2008 | Sony I/M CMT-CP1 98 FRENCH Shelf System
    Shelf cds is blocked SONY CMT-HP7
    To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
    Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
    CMT-BX1 won't play CD's - "No Disc"
    If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
    Sep 16, 2007 | Sony CMT-BX1 Shelf System
    94 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
