Question about Mongoose Tyax Comp Men's Mountain Bike
I need to know how to adjust the chain tension
  • 484 Answers
The only way to adjust the "tension" of the chain is to remove links. You will need a chain breaker tool. Shift the bike into the biggest chain ring and the biggest cog of the cassette, then break the chain, leaving the pin partially in the link but far enough out that the chain separates. Now, pull the chain together so that the rear derailleur's arm is as horizontal as possible and aiming toward the crank. Break the appropriate link to connect the chain so the derailleur stays in that position and reattach the chain using the pin you left partially engaged.
i hope this helps
-matthew
Posted on Nov 15, 2009
Testimonial: "Thanks Mathew, I am having problems with the gears and chains being "noisy" and the chain seems a little loose"
How can I tighten chain drive belt?
Chain belt? Don't think so. There is a timing chain and a timing belt. Timing chains on automobiles are generally non adjustable and are tensioned by a hydraulic tensioner and require no attention. Some timing belts are also tensioned by a hydraulic tensioner requiring no service. Some timing belts are also tensioned by a cam tensioner that can be adjusted but are rarely in need of servive unless the timing belt is being replaced
Feb 13, 2016 | Cars & Trucks
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
How to adjust timing chain 2003 honda accord
the timing chain is adjusted by an oil pump chain tensioner and is to be renewed at each chain replacement. from this it is hydraulic adjustment and is automatic and does not require manual tensioning
Jan 06, 2015 | 2003 Honda Accord
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
I cannot find my manual to my 18v cordless chainsaw ccs818. I need directions for putting the chain back on. I would like to download a copy of the manual.
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Nov 08, 2010 | Black & Decker Garden
Xr 350 timing chain slop makes noise can i adjust it
Both the 1985 honda xr250r and xr350 look loke they have self adjusting cam chain tensioners. You may have a broken tensioner or tensioner guide. With the age of the bike you may need a new cam chain. There is nothing to adjust so you need to just figure out if the chain is stretched , if a guide is broken, or if the tensioning mechanism is malfunctioning.
Oct 01, 2010 | 1985 Honda XR 250 R
Timming chain adjustment
Most likely you have anautomatic cam chain tensioner, which cannot be tensioned, and the only remedy is to replace the cam chain (if it's stretched). If, however, you have a manualy adjusted cam chain tensioner (highly unlikely), you have to look up the tensioning value in your workshop manual.
Jun 13, 2009 | 1986 Yamaha FZ 600
ZX6 Noisy Cam Chain
if your chain is makeing nois it would be a good idear to replace the chain a manual cam chain tenshioner will take the slack up but what about the valve timeing a worn chain will throw it out due to the chain stretching plus the manual tenshioner will make the guides wear faster if ya auto matic tenshioner has reached its limit that means replace chain no ifs or buts
May 08, 2009 | kawasaki ZZR 600 Motorcycles
Mitsi Montera/Pajero/Magna 2.6 timing chain tension
The 'special bolt B' listed in the Haynes manual allows adjustment for the silent shaft chain, not the timing chain.
I don't know why there is a phillip head screw instead of a bolt.
Jan 17, 2009 | 1992 Mitsubishi Montero
Mongoose Tyax Comp Men's Mountain Bike  Logo
360 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
