Question about LG Washing Machines
LG fuzzy logic wf-t85b31ec has come up with error code "dE" but we are unable to identify the door latch/locking assemly to fix. Any advise, thanks
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
  • 472 Answers
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
Posted on Jan 06, 2011
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Apr 17, 2016 | LG WM Washing Machines
Have a LG fuzzy logic 8.2kg wf -8071ttp it gives a de error
DE usually means door open,can also mean that door lock not working
Dec 20, 2015 | LG Washing Machines
DE error massage on lg fuzzy logic 8.2 kg 8071TTP
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Jun 22, 2015 | LG Washing Machines
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
Where is located sensor of. Fuzzy logic t7517tepto
dE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Dec 10, 2014 | Washing Machines
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Washing Machines Logo
78 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
