Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
My verbatim usb160 worked the first four times I used it, but now my laptop is not reading the drive. It does work on my home computer. But if I can't transfer my data, what's the point?
  • 748 Answers
There may be several causes for that.
If you say, that the drive reads OK on a desktop computer, but not on a laptop, then the drive itself is fine.
First, try to establish, whether the drive spins up correctly when attached to a laptop. Hard drives need a considerable amount of power to spin up (the first second or so), usually slightly above the 0.5 Amp limit that USB specifications require. Desktop computers, as they have a large power supply, can output this momentary extra current without problem, whereas laptops, where power is tightly controlled (to facilitate longer opearation on battery), may have the output power more strictly limited. Try all the available USB sockets on your laptop, sometimes one of them will be able to give just enough power.
If the drive spins up correctly, and you hear the familiar "USB device attached" sound, then the next step will be to check the Disk Management if the drive is seen by the system.
Assuming you have Windows XP or Vista, go to Administrative Tools and find Disk Management (you can also right-click the My Computer icon on desktop and choose Manage).
When you click Disk Management on the left, you will see on the right side the drives and volumes found on the computer. If you see, apart from your first hard disk (the one that contains the C: drive volume), another disk of the size similar to the size of your USB drive, we're good. You can right click the volume on this drive and choose "Assign drive letter", choosing a letter near the end of the alphabet, like "V" for Verbatim for example. Confirm the operation, and go to My Computer to see if the drive appeared as a V: drive.
Good luck, and don't forget to come back with a testimonial if helped :)
Posted on Nov 15, 2009
My mobile gt s5302 drow patan is five time worng then mobail user neme and pasword
1. Switch Off Your Phone
2. Press and hold Home Button + Volume Up + power on button
3.You will get four options and Select Wipe Data/ Factory Reset Option using Volume Key . Then Confirm by Select Yes Delete All User Data. Using Volume Down Key and Confirm it.
4 REBOOT NOW
May 29, 2014 | DURAGADGET Protective Case With Soft...
Verbatim store n go usb flash drive 8 gb device not recognized
My Verbatim Sto N Go 8GB USB Flash Drive does not work in any port, in any computer. When I plug it in, the "Device is not recognized" error comes up. When I click on it, and the Unknown Device Properties comes up, the device status reads: "Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer."
The driver details read:
Provider: Advanced Micro Devices
File Version: 1.0.11.82 built by: WinDDK
Digital Signer: Microsoft Windows Hardware Compatibility
This is the 2nd drive of this same brand that quit working within 6 months. I have MONTHS of work on files in this drive, and would hate to have to redo all that work! I was real careful after the first one went bad to use the eject button when removing it from my computer. But I am thinking the last time I clicked the eject button, it froze, so I just pulled it out without the message coming up. Hopefully there is someway to get the computer to recognize this drive again???
Sep 26, 2012 | Verbatim ® Store `n` Go USB Flash Drive,...
I accidentally spilled water on my USB160 and now my computer doesn't read the drive. HELP! I
what happened when and after you spilled water on it was it connected and working at the time
did you? dry it out completely after you spilled water on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap if this solution does not work and you might need one
hope this helps
Aug 04, 2011 | Verbatim 160GB USB FireLite: The "drive...
I have a Verbatium USB160 S/N JH8Y01 When I plug it into my laptop all I get is a flashing light on the drive. It did work at one time and I was able to back up to it. I read that the usb cable that came...
Does the drive have external power (D.C.) adapter? If not try to use a 2 ended usb plug to make sure the drive is being powered up. Does the computer see the drive? go to my computer\manage\diskdrives
Jul 12, 2011 | Verbatim 160GB USB FireLite: The "drive...
Verbatim Store 'n go 8GB - s/n 1501-0608-03999. Copied data to the drive on one laptop. Inserted into another laptop to read and it was ok. Now I cannot read on any laptop. Light blinks but will not...
My first question is: what platform (PC or MacIntosh) are these two laptops?
Secondly, are both laptops using the same operating system?
Your Verbatim drive should be formatted to be compatible with the operating systems being used.
I certainly wouldn't throw it away... but you might not be able to retrieve the files that are on it.
Try inserting it into one of your laptops. Does it show up? Try the other laptop. Does it show up?
If "yes" on either laptop, try opening it, or clicking on it & trying to get information on it. That will give you some clues.
  • If you're running Apple OSX, you can open "Disk Utility" and view it, repair it, or reformat it. It's pretty straight-forward.
  • If you're running Windows, you can click on "My Computer", then click on "Manage" in the Explorer window. Open the "Device Manager" and click on the "Disk Drives" tab. Do you see it? If so, right-click on it, and then select "Properties". Then click on the "Policies" tab & select "Optimize for Performance", then select "OK". Click on "My Computer", select "FAT32", then "OK".
If you did this correctly, you thumb drive should now work on all Windows operating systems.
Mar 03, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
No computers will recognize my externaml Hard drive. Its model number is usb160. whenever i plug it in to anything, all it shows is a flashing blue light. Can you please help?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Verbatim 160GB USB FireLite: The "drive...
Unable to safely eject
Just completely "shutdown" your computer, and then disconnect the USB cable. Then, you should be able to manually "eject".
Apr 17, 2010 | Verbatim 160GB USB FireLite: The "drive...
Where can I get a new usb cord for my Verbatim usb160. It works if I wiggle the cord.
If your close to a radio shack they have them, you can also go to
www.monoprice.com
they sell just about any cable made and then some.
Jan 29, 2010 | Verbatim 160GB USB FireLite: The "drive...
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Nov 21, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
376 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
