Question about Water Heaters
Hot water wont fire up when hot tap is turned on . but firing up for radiators ok
My cold water tap is hard to turn on to get water, what could the problum be ?
Posted on Dec 03, 2009
    Scholar:
  • 150 Answers
Check the diverter valve is operating when hot is on demand. Depending on the boiler [valve types differ] most have a small piston [biro refill diameter] protruding which operates an electrical switch/contact.
replace switch.if valve piston works but not the switch OR it piston not working
replace valve [or diaphragm inside]
Posted on Nov 22, 2009
My Mersey Super Gas Fired Water Heater not working properly , pilot is on but w t fire up when I turn hot tap on
Could be the diaphram in the water section not working or a blockage in the water section ie lack of water pressure to open gas .
Jun 21, 2017 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Why does my Takagi tankless water heater fire up briefly when any COLD water tap is opened? Unit is new; installed per mfr's instructions; works fine when HOT water faucet is turned on.
Because when you turn on the cold water the pressure drops in the feed to the heater, so the pressure switch fires the boiler up. Call the installer back.
Oct 21, 2015 | Water Water Heaters
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Our atwood heater is firing up ok and running for a good while then turning itself off but we dont get any hot water out of the hot taps. Our water pump is working ok but we have this funny tap within the...
Cold goes in bottom fitting of water heater, so that valve has to be open, and hot comes out the top, so that has to be open, if there is one there, but any valve in between needs to be closed. There are a few variations so if you can explain where your valves are located in the system more precisely, I can help better. Perhaps you can send a digital picture with reply?
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
Wont stay fired up
Bosch tech support will ask you to turn off the valve to the water heater and open a hot water tap. If you have water flowing it is likely from a shower valve. My experience is Price Pfister shower valves are usually the culprit. Let me know how this turns out.
Apr 09, 2010 | Bosch GWH 425 EF N Water Heater
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
Water Heaters Logo
216 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
