Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
I'm not able to see the names of the people in my phone book
When ever i try to access my phonebook it comes up "TDN enabled" what does this mean? how do i fix the problem?
Phonebook is organising my contacts by surname, name!
There is a field called 'display name'. Address book will show the entries however you mention in this field. So, put the proper name in this field and check.
Sep 02, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Tip
BLUEJACKING
<span>First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone.</span>
on Jan 01, 2011 | Cell Phones
Can't open the phonebook of my motorola e398
Motorola E398/Razr address book disappears/bounces:--Solution
press 1+# (i.e. speed dial #1)
press Menu -> Categories -> Select -> All
Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
Dec 11, 2008 | Motorola Mobility E398 Cellular Phone
Locked out of phone book
its not the problem go into securites and unlock ur phonebook ur code is 0000 and ur securite code is 00000
Jun 03, 2008 | Motorola Mobility RAZR V3
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Motorola V3 Phonebook problems
ur phone needs a software upgrade or just a flash
Mar 13, 2008 | Motorola Mobility RAZR V3
Phonebook
If you tell you phone company, they would most likely replace your phone for free if you tell them that its defective. T-mobile does it for sure. Hope I helped. =)
Feb 24, 2008 | Motorola Mobility RAZR V3
Phonebook access
i can help... i have incurred this problem a couple of times and understand the frustration! firstly, the reason why snd how this problem occurs is you have saved a number to your phonebook without a name and this causes the phone book to wig-out! to fix the issue simply press "1#". This will allow you to view your phone book in its speed dial order. Scroll through this menu until you find the saved number without the name and DELETE it. This will immediately bring your phone book back to normal. Good luck!
Dec 22, 2006 | Motorola Mobility RAZR V3
Phonebook problem
is your phonebook located at the sim or in the phone book?
Cant access phonebook
your on the right track 1# then scroll through to find the number without the name and either delete it or add a name to it
Nov 07, 2006 | Motorola Mobility V300
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
16 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
