Question about Nokia 3110 Cellular Phone
Hiss noise Dear Experts, My Nokia 3110c generates quite an annoying hiss noise when playing music or any other sound. I think it might be normal for this type, but it makes the phone nearly useless as an mp3 player. Can you give me any solution? (I have tried to install another music player programme on the phone but that didn't lead to a solution.) Thank you for your help!
  • hg23nagy Nov 15, 2009
    Dear rain_cacher,
    Thank you for your immediate resopnse. I have tried the things you mentioned, but I'm afraid they couldn't solve the problem so far. When lowering the volume, the hiss is still there and doesn't even sound to get more quiet as I turn the loudness down.
    The hiss is not part of the mp3 file, that's for sure, as when played on another device (e.g. computer) no noise is given.
    Actually, the hiss is there whenever anything that has to do with sound is played, it can also be heard under the key-beep sound.
    I use a pair of earphones, but the own little built-in loudspeaker of the phone does the same, but with the speaker only when music is played, not the beep-sounds, for instance. The problem's not with the earphones, I have tried it with different ones.
    The phone has done it since I have it.
    And finally, don't think it is a noise which is almost louder than the music itself, it is quite quiet, but in the case of some more quiet music, it can be quite annoying. Well, I'm really starting to think that this lower sound quality is just a normal weakness of this oldish model. But I still hope that you or someone else has something to add.
    Thanks again for your help, I'm looking forward to any further ideas.
  • hg23nagy Nov 16, 2009
    Hello!
    I've tried the soft reset - well, as I expected it didn't help unfortunately, but thank you for your help anyway. And for your kind offer - but I live in Hungary, Europe, kinda far from Milwaukee. :D
    Now what I really think is that as the 3110c is not the latest model, this poorer sound quality is simply a feature of it, just like the lower screen resolution etc. Disappointing, though...
    Thanks again!
    Sergeant:
  • 267 Answers
Its never normal for your phone to make sounds other than what you want it to make. try lowering the speaker volume to the lowest setting but still allow yourslf to be able to hear. check to see if its still making the sound. if so try getting your music from a diffrent source. if that also fails try voice record if its avalible on your model phone. play voice listen for the unwanted noise. reason for this is to narrow the problem . how long has the phone done this?
your phone speaker is most likely the problem seeing that even the phones own tones has a static sound.
could have blown speaker .
Posted on Nov 15, 2009
  • rain_catcher
    rain_catcher Nov 15, 2009
    im so sorry i couldnt be of any help. the reason i asked these things was to narrow it down . you will need to service or replace your phone dear and with that being a older model i subjest you replace it. it will be cheaper than fixing it. if you lived in milwaukee i would just give you one of the many phones i got. lol
    the only solution to your problem im affraid will be to replace or service it. your problem seems to be more with the function of the phone. my last subjestion is to try a soft reset.
    here is the code.
    ----------------------------------------soft reset code for nokia--------
    Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
    This function apparently works on almost all nokia mobile phones.
    if this fails you will need to replace or service your phone im affraid.
    this code will set your phone back to factory settings
    make sure you save important things .
Amplifier Backroung hiss Noise Problem
Unfortunately, it's a design or manufacturing problem with all of these. If it's new enough return it and get a different make of amp.
Sep 04, 2016 | The Music
6505 +112 has a bad hiss with nothing plugd in
Some hiss at high gain settings is normal. If you get objectionable hiss at 1 o'clock settings of gain, that is too high. Electronics has noise that is "statistical" in nature due to physics that we can't get around in design. Most hiss is created in the preamp area and swapping tubes in the first stage might help. By varying the volume controls and observing the level of the hiss, we may be able to analyze the offending staage of amplification. ALso turning up the treble controls will increase the hiss, as it is mostly in the higher pitches.
Jun 26, 2011 | Peavey 6505 Plus 112 60w All Tube Combo...
I have hiss on my clavinova cvp 301 what can i do to eliminate that?
The source of the noise could be many things. At real high volume levels with no notes being played, some hiss is common due to the statistical properties in electronics. At a normal listening level the hiss should be inaudible. If there is a failure there is little you would be able to do yourself to repair it. One MIGHT use circuit cooler to isolate a bad component, but it is unlikely you would have the tools to replace it as most everything is surface mounted. If you have a treble control, turn that down to reduce the level as the hiss is always up in the higher registers.
Apr 25, 2011 | Yamaha Music
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
My swr workiongpro 15 suddenly has a very noticable hiss even when the amp is muted, and when I play the high end is more prominent than it was before.
If you are having the treble/high turned up there will be hiss. This is due to the statistical noise in electronics, including semiconductors. It is a matter of degree. The hiss should be 30 Db below your program level or so.
It is very common for one to change settings and suddenly start to notice hiss or hum at certain settings.
IF YOU CAN, go to a music store and COMPARE the amp to yours at the same setting with NOTHING plugged in. (cables and guitars can generate hiss or other noise themselves).
There is very little in your amp that would have changed to suddenly start generating hiss, so FIRST compare. This will minimize the chance of spending money at a shop to be told it is normal.
Sep 14, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
When i turn up the lead knob there is a loud hissing sound
That is indicative of the statistical electronic noise common to amplifiers. It depends how loud it is relative to the program level. If you get no output while this is turned up, then likely the input to that section of the circuit has failed and that will worsen the noise problem. At wide open you can expect to hear some hiss... probably an annoying level if you are close to the unit. This statistical noise is a problem that plagues engineers and part of it is due to the laws of physics... there are some chips that have better noise performance, but none can totally eliminate it... you can't fool mother nature as they say.
It is always important to balance the gain of the inout preamos against the master volume. MOST of the noise is generated at the input preamp area rather than the power amp, so make sure you have adequate master volume set.
Feb 11, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Nokia 3110 Cellular Phone Logo
185 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
