Question about Cell Phones
I just bought a T-Mobile Tap and I can't pair my Jabra Bt2010 with it, any suggestions?
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
I paired my jabra bt 2015 with my mobile N91 NOKIA then i bought a new mobile nokia 5530 xpress music i can't pair it with the new mobile why ??? please help me
Go to Jabra site to confirm compatibility:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabrabt2015.aspx?submit=y
It says that they are compatible.
Dec 21, 2010 | Jabra Bluetooth Headset with Adjustable...
I cant pair my jabra with my phone and i dont have the pin bt2010
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
the PIN is 0000
Nov 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra bt125 won't pair to motorola razor v3
I had the same problem and found the user: Splut wrote in another problem the following solution: If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you. DIVA08
Dec 15, 2008 | Jabra BT125 Headset
Sigamtel S4 and Jabra BT125
SET YOUR BT125 JABRA  in pairing mode then try to seek in mobile
or reset your mobile
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
Connecting to a jabra hands free
once you have found it it should then ask for a pin code which is either 1234 or 0000
once this is accepted then they should be paired completely
Nov 25, 2007 | Cell Phones
Cell Phones Logo
120 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
