Question about Toshiba Satellite A135-S2276 Notebook
My webcam only starts if i cover it first then take my finger away.. and then it freezes about 5 seconds later and doesnt work again
    Sergeant:
    Champion:
  • 215 Answers
Try uninstalling the webcam driver and reinstalling it again.and see if it works.
Posted on Nov 15, 2009
My vt60 winw cooler doesnt cool , it will show the degrees you want to set it at then few seconds later it goes back to the room temp. of 76...also makes clicking noise to start compressor then again a...
Sounds like the compressor is frozen - sound you hear is the clixon a special sort of resettable fuse on compressors. When they do not start or overheat, it kills the power - when it cools power is restored until it reheats again and .......................
Use ammeter to confirm this - it will show a much greater than normal current draw.
Apr 22, 2014 | VinoTemp VT-60 Wine Cooler
How do i change the sand in the hayward model sp 711
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
My playstation 3 turns on but the av multi out doesnt work so i cant see or hear anything.
Try resetting the display by doing the following:
Step 1. Turn the PS3 off into standby (red light on)
Step 2 Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3 Wait for your PS3 to start
Hope this helps
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
TV TURNS OFF ITSELF AND 15 SECOND LATER IT COMES
This is a Heat issue with the front sensor of the TV. Dust and Dirt block the sensor causing it to heat up faster and faster. Cleaning the lamp is extremely easy and it will get the TV working again, at least for a short while and then it will happen again. I know cause its been happening to me and it will work for about two weeks and start happening again. Sony actually has a class action lawsuit against them for this issue. Long story short here are the steps to correct the issue:
1. power down TV and disconnect from the power outlet then let sit for 30 minutes until its colled down 2. On the bottom corners of the TV (Back side) you will find a round screw that you can loosen with your fingers 3. once both screws are lose the front bottom part of the TV will pull off, there are magnets there so it will hold it in place temporarily. 4. Once the cover is removed, in the center of the TV will be a little door with another Finger screw to loosen, once off move the bar holding the door closed and remove the plate. 5. You will need an Alan wrench, the screw will be in the upper left corner, when this is loosened the screw will not fall out and you can pull out the Light fixture 6. CAREFULLY with compressed air spray the light assembly and the inside of the TV very well and then replace the light bulb. 7. Put the Door back on the front of the Light area, and assemble the rest of the TV in reverse order before testing the TV. I have done this multiple times as this is not a permanent fix but does restore life for a short period of time.
Feb 04, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Video conferencing starts fine but after a minute or so my video freezes. When I turn it off and on again it starts back up but only for about 20 seconds until it freezes again.
If you are trying to use Yahoo conference facility put your webcam under Video For Windows control ( VFW )
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamtest.html
You have use IE to automatically download this program by just visiting the page - it will make a small registry change and for me, increased the frame/per/second f/p/s by 100%
To check your webcam is working in VFW when broadcasting in messenger, open 'Webcam' menu on the frame and select 'Statistics' VFW should be displayed on the bottom.
Also save resources by transmitting the small picture option and your contacts can zoom up to 200% using the 'Webcam' menu on the top of the picture frame.
Aug 09, 2009 | Creative Labs Computers & Internet
Freezing while making video
Try connecting to another USB port preferably to the back of pc not through any hub. Uninstall and then reinstall camera driver carefully following procedure in the accompanying manual.
Jul 28, 2009 | Philips SPC610NC Webcam
WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
Jun 18, 2009 | U-Line BI-95
Hanging
freezedMy HTC was working great!!...sudenly started to freeze and after that just turned off...I try to soft reset it....but it is still hanged how can i hard reset ?it worked at the begining(just for 2 seconds) but later the phone didnt start....and then it didnt continue the starting..sometimes after that just a clear white screen appeared. it freezed again.touch screen not working at all.
Sep 20, 2008 | HTC Touch P3450 Smartphone
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Toshiba Satellite A135-S2276 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
