Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
My 8gb imation pen drive is not working. it is not being detected by the system and contains important document which need to be recruited
  • 28 Answers
If it can be detected on other computers (Macs or linux) than the documents can be saved. If cannot detect on other PCs you will need someone with the knowledge to recover files from memory chips.. Good luck..
Posted on Nov 15, 2009
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
How to view Hidden Files on a Pen-drive?
I f you are using windows 7
  1. Go to Control Panel
  2. Chose Appearance and Personalization
  3. Folder Options
  4. Show hidden files and folders
  5. Chose view tab
  6. And check (Show hidden files, folders)
Feb 09, 2012 | Imation Products - imation - Clip Flash...
Imation 8GB pen drive problem. When I type in my
Check this: Right click - EXPLORE
Check if your USB drive has somekind of a button (sometimes looks like a tiny bar) it's a hardware lock
Jul 22, 2010 | Computers & Internet
My 8GB imation was fine yester day, but it's
Yes first you need to recover your data so yo must use a tool to do that, maybe the "Pen Drive Data Recovery" can help you, I think it free you must search for it at google, and then when you stract your information you might use a Low Level format tool to get you're USB flash drive working again such as the hdd-low-level-format-tool, you can find these two tools at google
Mar 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen drive problem
Click Start, click Run, type compmgmt.msc, and then click OK. 2. click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. assign a new drive letter which is not used by any of your drives in My Computer.
5. After assigning the new drive letter your pen drive will show in my computer.
Feb 25, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Pen drive issue
Try a totally independant PC away from the ones you tried....if no go drive has failed and data will be lost sorry.
Jan 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My pendrive is not detecting
maybe it's not working because it's not working
Mar 13, 2009 | Kingston 4GB Secure Digital High Capacity...
Cpu won't detect nano pen-drive
I sold the nano pen drive to my friend :-) i just use a kingston pen drive. I think maybe the fujitsu fmv couldn't support/read the nano pen drive "cause i've installed the driver from imation web site but it still won't detect the nano pen drive.
Dec 10, 2008 | Electronics - Others
I ' VE Pen Drive Problems
Install Tweak UI---Please rate my solution
Oct 22, 2008 | Computers & Internet
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
273 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
