Before I had to reinstall the programs cd my computer asked me if I wanted to save all my files on my internal memory. I clicked yes. Now how do I bring those files back? Gateway desktop windows XP
You waint save all files on internal memory.
totel files tak backup any drive.
Posted on Nov 15, 2009
Factory reset from CD
Click the "Start" menu on your computer and choose "Accessories." Click "System Tools" and choose "Back up" from the list. This process will back up any files on your computer that you wish. When you reset your HP to its default settings, all documents, programs and other files on your computer will be lost. Back up anything you may need later. Follow the on-screen instructions to move through the back-up wizard. When given the option "Let me choose what to back up," select all programs or documents you want to save. If you're unsure whether you'll need it, back it up just in case. Insert a blank CD or DVD to save your files. Choose your CD drive from the "Back up location" option in the backup wizard. Keep multiple blank CDs or DVDs on hand. You'll need a lot of space, and typically several CD's, to back up all your information. Click "Finish" at the end of the back-up wizard and it will begin to burn information to the CD or DVD. When prompted, remove the CD and insert a new one. Continue until the computer is done backing up your information. Label each CD or DVD in the order you burn it. This way you can transfer your information back into the computer in the order you saved it. Check your CDs or DVDs to make sure the back up was complete by opening a file from the CD. Exit any open programs. You are now ready to start the restoration process. Click the "Start" menu, "All Programs," "System Recovery," and choose "PC Recovery." Choose "PC Recovery" again once the menu opens and click "Next." Your computer will restart automatically. When it turns back on, a welcome message for the PC Recovery software will display on screen. Click "OK." Select the "System Recovery" option to restore the computer to its default settings. Follow any on-screen instructions and wait for the computer to finish resetting your settings to the default. Insert your first back-up CD or DVD to start reinstalling your programs after boot-up. Open the files and save them to the computer. After you've saved everything from the first CD, continue on with the rest. Hope this helps.
Jan 09, 2013 | HP Computers & Internet
Add ram
Each computer contains two important components---a Central Processing Unit (CPU) and memory chips. The CPU and memory chips work together to process computations within your computer. You can't have one without the other. Your computer has a base amount of memory installed, 512 Megabytes or higher, that can be expanded to beyond 1 Gigabyte, in most cases. Before you upgrade your computer's memory, you need to know what type of RAM your computer takes: SDRAM (Synchronous DRAM), Rambus DRAM (RDRAM), DDR (Double Data Rate SDRAM) or other type.
Open your computer's Internet browser by clicking on the program's icon on your computer's "Desktop," this applies to both Windows and Mac platforms. Enter www.crucial.com/systemscanner/index.aspx in the URL box at the top of your browser's screen. The "Crucial System Scanner" tool application website will open. Click on the check box next to the wording "By selecting this box and clicking the download the scanner button, I agree to the Terms and Conditions." Click on "Download the Scanner." The "Opening CrucialScan.exe" dialog box will open. Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer if you don't see the "Open" or "Run" option or you are using dial-up or a slow Internet connection. The program will download and setup on your computer if you selected the "Open" or "Run" option. Navigate to the directory where you want to save the file, if you selected the "Save" or "Save As" option. Select the "Desktop" if you have a hard time locating downloaded files on your system. Double click on the "CrucialScan.exe" icon to open the program, if you selected the "Save" or "Save As" option. Click "Run" when prompted with the "Open File -- Security Warning." The "CrucialScan.exe" program will run and appear in your computer's Internet browser. Scroll to the second section on the "Memory upgrades from Crucial.com -- Determine My Memory Needs" website. The section is labeled "Your XXXXX Specifications." The "XXXXX"s represent your computer's brand and model. Locate the wording "Each memory slot can hold..." Write down the this sentence on a piece of paper---this is the type of RAM your computer accepts. Click "File," "Print," "OK" to print this website, if you have a printer attached to your computer. If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
Dec 16, 2012 | Sony VAIO PCG-885L PCG-9411 PCG-948L...
To reinstall it. booting it doesn't work. So need to have reinstall. do I need a disk?
Yes, if you want to reinstall the copy of your Windows installed in your computer you need to have a Windows CD.
But try doing System Restore first on safe mode if you still can before doing a Windows reinstallation or repair to save money from buying a WIndows CD and from loosing all your files in your computer.
To do system restore on safe mode:
1. Restart your computer and when the Dell Logo comes up and keep pressing F8 until an option shows
2. Use arrows to navigate then choose safe mode
3. Click start button then choose All programs or Program depending on the Windows installed in your computer
4. Click on System tools then choose System Restore
5. Follow the intructions on the System Restore windows on how to restore your machine back to a previous date before this issue happen.
6. Your computer will automatically restart after restore is done
Hope this information will be helpful. Thank you for using FIXYA.
Apr 16, 2011 | Computers & Internet
It can read and detect discs, but cannot burn songs. Any idea?
Hi Jaun,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Dec 29, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
No sound when playing dvd on lg gp08nu20 plugged into asus netbook
Hi John,
    • Reboot
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 28, 2010 | LG GP08NU20 DVD±RW Burner
I carnt play dvds or pc games on my laptop its says error
Hi Della,
    • Reboot
Dec 28, 2010 | Computers & Internet
No sound on Oritron DvD 3116
Hi Trotter,
    • Reboot
If you take all these step and you still have no sound, chances are your CD/DVD componet needs to be replaced. Good Luck,
Dec 27, 2010 | Compaq (311627-001) CD-RW/DVD-ROM (Combo)...
I've installed Printshop 21 on my new computer. I
Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
Nov 14, 2017 | Broderbund Print Shop® 21 Pro Publisher...
Burn Outlook Express files onto disk
You can make a copy of your .pst file which essentially holds all of your email. Do a search of your computer for *.pst. Make a copy and paste where you know you can find it. Right click the copy of the file and select send to cdrom from the drop down list. You're task bar will pop up saying you have files waiting to be written to cd. Click this windows, select burn files to cd from the left menu.
May 01, 2009 | Computers & Internet
Unable to Save - Internal Error
Use your burning software or similar ones like NTI CD/DVD maker, Nero or EZCD Creator and start new DVD DATA job. At the blank layout screen, drag your cd drive letter into the layout. The software should ask something like "do you wish to load the previous image from cd drive?" Click on yes and you should see the folders and files re-appear. Change the name of one of the folders or files and then re-burn. This should re-create the DVD data structure so you can access it properly.
Jun 27, 2008 | Autodesk AutoCAD 2004 for PC
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
