Question about Trust Predator QZ 501 (13276) Joystick
Trust QZ 501 predator joystick. i want help for the settings.
I need the gamepad's driver for Windows XP.
http://www.trust.com/search/default.aspx?cxt=drivers
Try that website to see if you can find a driver for XP. Honestly, if it is newer, you may NOT have compatibility directly and you may have to use XPAD or something similar to map the controller.
May 13, 2011 | Trust Predator GM-1520 GamePad
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
I have just bought a new mouse for my computer, un packed and connected the mouse to my computer as instructed. switch on computer mouse does nothing ,will not move cursor
It will need drivers, to install drivers use the bundled CD and install from there, if you dont have one the you can get drivers from here
http://www.trust.com/products/product.aspx?artnr=14463
if it does not work after installation of drivers then you need to replace it.
Good Luck, and do rate the solution if helps
Dec 30, 2010 | Trust Predator GM-4200 Mouse
Hi, I bought a Trust gm-2500. When I plug it in to the computer it says that it has stopped for a problem with it. Is there any solution to it?
Trust Predator GM-2500 joystick
USB not recognised! USB lead needs replacing, any help please :-)
many thanks
Nov 03, 2010 | Trust GM-2500 Joystick
How can I install if I havent got a Cd or any other files? I just got the joystick only, and my computer cant see the USB port including the joystick... wot now?
There should be no driver needed for this under WinXP/Vista
First, make sure that the USB port you're using works -- plug in a different USB thing into that port, even just a mouse, and confirm that the computer sees the device and it works.
You can also try plugging the joystick into a different USB port on the same computer, or take it to a different computer to see if it works there.
If this helps, please be sure to hit the "thumbs-up" for me.
If not, use "add comment" to tell me what you find from your troubleshooting, and I'll try to get it worked out for you.
Jan 09, 2010 | Trust Predator TH 400 (12629) Joystick
Do I need to download a specific driver for this? I control panel there are a number of generic joystick types (2 way, 4button etc, but nothing which exactly matches the Trust GM-2500
According to the Trust website, no drivers are needed:
http://www.trust.com/products/productdrivers.aspx?artnr=14274
There is also a quick install manual for it by clicking on the button:
http://www.trust.com/products/productmanuals.aspx?artnr=14274
Just follow the driections on whether you have Vista or XP.
Dec 05, 2009 | Trust GM-2500 Joystick
Wb-1400 webcam
The 'filter
> graph' message comes from that. I suggest running the command "DXDIAG" to
> see what tests fail, and what you might do to reinstall DirectX.
> Download details: DirectX Redist (June 2007) :
> http://www.microsoft.com/downloads/d...displaylang=en
Jul 09, 2008 | Trust Predator TH 400 (12629) Joystick
Trust Predator QZ 501 (13276) Joystick Logo
263 people viewed this question
Top Trust Video Game Consoles & Games Experts
James Wishart
Are you a Trust Video Game Console and Game Expert? Answer questions, earn points and help others
