Question about QDI Group QDI KinetiZ 7E-A Motherboard
It is not detecting hard disk and cd drive. - QDI Group QDI KinetiZ 7E-A Motherboard
    Scholar:
  • 124 Answers
Have you enabled the drives in BIOS? At Boot press deleate key enter bios enable the drives
Posted on Nov 15, 2009
    Problem Solver:
  • 10 Answers
Make sure no leads or any connections are loose or dislogd as it happends in side your cassing
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
I cant formate my c drive with bootble dvd or cd
The hard drive may be faulty.
Go into the BIOS setting and see if the BIOS detects the hard disk, if not reseat the hard drive and if the BIOS still does not detect the hard disk then the hard disk is faulty.
Nov 30, 2011 | Seagate HDD Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
DIY solution for data recovery on a failing Hitachi HDD
Yes it is possible to data recover from this hard disk to using "active partetion recover v2.0 or above" software. This software should be registered and also bootable disk. It will be possible to data recover, if it will be detect in dos mode.
Procedure:
Insert the bootable disk into CD-Rom and choose boot from the cd rom and now check your disk is detected or not, if detected follow the instruction and your all data could be recover with your complete partions.
Good Luck
Dec 14, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
QDI Group QDI KinetiZ 7E-A Motherboard Logo
152 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
