Question about Sony Cyber-Shot DSC-P9 Digital Camera
Sony camera formatting disk error C:13:01 need to retrieve photos
I have a sony camera, i put a new memory stick in it, and took roughly 50 photos and then it suddenly said formatting error C:13:01... i plugged my camera to the computer to at least retrieve the photos and it says my sd card needs to be formatted IS THERE ANYWAY I CAN RETRIEVE THE PHOTOS BEFORE FORMATTING ITS VERY IMPORTANT TO ME. thanks
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
I have a sony dsc-f717 took several pictures and now i get format error 13:01 and can't retrieve the photos I've took and veiwed. Help retrieving
1st, try and download the pictures via your computer and a memory card adapter. If you're computer doesn't recognize the card through an adapter,
2) go to www.ita.sel.sony.com
Search by the model number of the Memory Stick. There is Memory Stick recovery software. follow the steps for the download and recovery.
3) On new/blank memory cards, I sometimes have to format the MS in the camera first, then everything works fine.
Jun 28, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
How do I retrieve photos from my built in memory storage if I don't have a camera to computer hook up wires?
Put memory stick in camera, power up and press Menu on camera, select Copy option and press OK
That will copy photos from internal memory to memory stick.
Jun 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
File error
It means memory stick is unstable / worn out. Format memory stick by pressing Menu > format. If problem is still there, put new memory stick in camera.
Jun 05, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
When i turn the camera on it says format error and i cant take any pictures
Please take out memory stick from camera and power up camera and check still gives format error?
If no further error then put memory stick back in camera and press Menu >> Format >> OK to format memory stick. That will delete all data on memory stick and refresh it for new photos.
May 17, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Memory stick format
You can search on google 'file recovery' software and download it. many software are free and works fine.
Feb 25, 2009 | Cameras
Memory card formatting error
Yeah, if you format the memory card, you will lose all data on it. try to scan memory card with updated anti virus software and always use memory card by camera to PC.
Jul 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-P9 Digital Camera Logo
250 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
