Question about Samsung Digimax D53 Digital Camera
Wont turn on
If the memory card is in the camera will not start. It opens the lens and then stops if you take out the memory card it will come on all the way
  • basspastor Jan 20, 2008
    I do have a 256 mb card that is full.
  • 24 Answers
Try to see what type of memory card you're using, see if that's complatible wiht your D53. try to use lower memory capacity for your camera. D53 is in fact an old model so i suppose it supports memory card of lower capacity. try to use 256 MB memory card.
Posted on Jan 13, 2008
  • mark angelo sakay
    mark angelo sakay Jan 24, 2008
    if that 256 MB card is now full, try to delete pictures so memory card will work fine with your camera. have to try it with your camera? is the lens now working with your camera with that memory card?
SOURCE: Lens Struck
I had the same problem for several dads. I know this sounds silly, but after reading about numerous people having the same problem and without many solutions offered, I tried the somewhat weird suggestion of shaking my camera vigorously around and it worked! I promise.
Posted on Nov 15, 2007
early1234
  • 871 Answers
SOURCE: camera wont switch on
hi there
actually, if you really want your camera to work, you should have a memory card installed as well as the lens.
but if your question is will that work w/o the lens and memory card...of course it will turn on. but it wont function. what i mean is, you cant use it.
hope you understand.
Posted on Feb 10, 2008
elektriki
SOURCE: Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Posted on Jul 19, 2008
arian07gapa
  • 62 Answers
SOURCE: Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Posted on Nov 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: Lens is stuck open while the camera is turned off.
push in on zoom when turning camera on. this is a firmware problem and camera needs to be updated.
Posted on Aug 27, 2009
My samsung st700 is brand new have it only a week and it has stopped working. when i turn it on the lens extents and then it stop, i have no screen and it will not respond and then the lens wont retract....
If you have been using this camera outdoors, then the one causing your problem is a grit of sand jamming the lens. Hold your camera with your right hand with the lens facing the ground. Next, tap the camera's base to your left palm while powering on the camera. You might want to do this several times. If it still wont work, and you can avail of the warranty to save repair cost.
Hope this helps.
May 12, 2011 | Samsung DualView ST700 Digital Camera
When I turn on my camera my lens wont open and it will beep and say Lens error,resart camera. What should I do?
Hi there lens error means lens guide pin damaged. Solution only replacing the lens But you can try these for luck.Please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 23, 2011 | Canon PowerShot A560 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
My camera is saying lens error and it wont open the lens
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 12, 2010 | Nikon COOLPIX S230 Digital Camera
Just says lens error and wont stop making grinding noise
Jun 16, 2010 | GE A730 Digital Camera
It just turned on fine , i took out the batteries and memory card then put them back in. it wont turn on
check lens barrel for any dirt etc stopping lens coming out, this sometimes stops the camera turning on. make sure the batt is full (sure you have!) good luck
Dec 06, 2009 | Canon PowerShot A80 Digital Camera
Lens wont open
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Aug 28, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Camera wont switch on
hi there
Feb 10, 2008 | Cameras
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Samsung Digimax D53 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
