Question about Sony VAIO® VGN-TX610P/B PC Notebook
My battery would not charge unless i hold down the wire that plugs into the laptop. what is wrong?
  • 458 Answers
You have one of two problems...
1. You have a short in your charger cord (AC Adapter)
2. You Have A Faulty DC Jack (the port where your charger plug plugs into)
Posted on Nov 15, 2009
1993 Jeep Wrangler charging problem
nothing wrong with the ECM unless it has the voltage regulator as part of the system
indicates faulty wiring and faulty alternator
have a load test done on the battery
have an auto electrician do a full charging system check
charging voltage should be 14.5-14.8 volts DC
battery voltage should be 12-13.5 volts dropping to 11 volts when cranking the engine
make sure that the drive belt tension is correct and the belt is in good condition
Dec 22, 2017 | 1993 Jeep Wrangler
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
I changed the front bulbs and now the battery won't hold a charge
Sounds like the battery was on it's way out, time for a new one. Unless there is something wrong with the wiring harness maybe a short! Sounds like it was just your batteries time though. Goo luck!
Mar 31, 2014 | 2004 Honda CBR 125 R
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
Battery/Charge Problems with my MC7801u Laptop
try draining power first from system, take battery and adapter out then push and hold power button for 1 min. after try powering your computer with adapter only, then try with battery, if same thing, means you have bad battery.
Jun 11, 2010 | Gateway MC7801u Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
No power off charge
Sounds like you need a new battery.
Jan 07, 2009 | Samsung V20 XVC 2400 Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Won't Turn On Unless Plugged In
What is the make/model of the laptop? It looks like the battery is not holding a charge. Have you tried to remove the battery and put the battery back in?
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Toshiba Satellite A105 Notebook
Sony VAIO® VGN-TX610P/B PC Notebook Logo
139 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
