Question about Brother Sewing Machines
Info on threading Brother DB2 B755-3, also what is the max size thread and needle, that the machine can use? Thanks Robert
jgwhomeequip
  • 1902 Answers
SOURCE: MANUAL FOR BROTHER INDUSTRIAL SEWING MACHINE DB2-B755-3
Go to brother.com . From there you will need to enter the model number and serial number to get the file for free good luck
Posted on Jun 01, 2009
  • 185 Answers
SOURCE: industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
Posted on Feb 27, 2008
SOURCE: Brother PR600 embroidery machine has
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
  • 5 Answers
SOURCE: Bobbin won't thread on my Broter DB2 B755-3
Manual here........
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 29, 2009
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
Why is my Brother DB2 B755-3 not picking up the thread?
You have to bend over and pick up the thread yourself. HaHa... Just a little humor in the mist of a problem... Seriously that is a tension problem. Adjust the tension dial slightly as you sew a double length of fabric. Sew a little, adjust, then repeat...Good Luck xo
Sep 18, 2014 | Sewing Machines
Brother ls 1717 keeps breaking upper thread. I have rethreaded and put in a new bobbin. Please help. What can I do to correct this problem?
Change needle--flat side goes toward back of the machine
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Check tension 3 or 4 is usually good
watch the thread take up lever --some machine have a problem that the thread comes off the lever
make sure the needle & thread are compatable
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Nov 04, 2010 | Brother Sewing Machines
The thread keeps breaking and i lost the manuel for brother xl 5130
try rethreading machine
thread tension is to tight -try 3-5-see if that works better
change needles
thread might be caught around spool pin -tension dial
needle & thread may not be compatable-try this & see if it works for you
Oct 22, 2010 | Brother XL-5130 Mechanical Sewing Machine
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
Industrial sewing machine top thread breaking
Dec 19, 2007 | Sewing Machines
Sewing Machines Logo
361 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
