Question about RTO Mini Quads
Hi, My sons Apache quad bike has no spark I have changed the ht coil and spark plug. Can you please help. Thanks
Hi my quad wont spark can you help ?
Posted on Jul 07, 2010
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
After changing teh coil did you check the gap between coil and kly wheel and as colin said if you spray wd 40 when trying start at the inlet carb if thers a split then the reves wil rev
Posted on Jan 20, 2013
It's the air inlet manifold where it joins from the air inlet to the carb and manifold to the carb you will def find a small split I have had the same problem ps hope this helps
Posted on Jan 05, 2012
    Problem Solver:
  • 10 Answers
Things to check: 1. Make sure the coil is grounded to the frame of the quad. Not against a painted part of the frame but a raw metal part. 2. The stator could be bad. 3. Could be out of time. I would try these things first, hope this helps. Good luck.
Posted on Apr 06, 2010
Hi, my little brother is having trouble with his 150cc quad bike, there's no spark going to the spark plug, can anyone help me?
does it have a coil ?
check the coil lead and leads are connected at other end of spark plug leads.
Jun 01, 2016 | Motorcycles
Weak fire on pocket bike
Hi, I do a lot with these bikes, I think if you are getting a weak spark there is a couple things to check. First, do you understand how it builds the power to create the spark? The magnet in the flywheel has to be very close to the magnito or coil, if the gap is too much it will cause a weak spark, if the magnet is weak, weak spark, if the coil is shorting internally, weak spark. If the plug wire is damaged, weak spark. I hope this helps you.
Jan 25, 2015 | Quad 47 cc / 49 cc Pocket Mini Bike...
Apache quad rlx250 ax
just guessing that you have already changed the spark plug??!! Handlebar on/off switch in the on position? (yes, I have seen this come to the shop). After this you need a shop manual to check wiring connections, resistance values..etc.. if not... might be shop time.
Mar 28, 2014 | ATVs
50cc apache quad spark problems
Could be the CDI. Check the stator and pickup coil specs with a multimeter first.
Nov 17, 2013 | ATVs
Roketa 125cc wont start! spark plug is not giving off spark?
Check the lead and connections between the coil and the plugs, the battery and the coil. If all else fails check the battery charge.
May 08, 2013 | Motorcycles
Klf 300 no spark at spark plug but got 12 volts both side of coil hope you can help its a 1998 model
Start looking at the brown wire that goes from the kill switch to the coil as the problem.
It will be the brown wire.
See this wiring diagram:
http://forums.atvconnection.com/attachments/kawasaki/1474d1253468289-wiring-diagram-1987-bayou-klf-300-bayou300awddiagram_1.jpg
The start relay can also be the problem.....
If you still have the problem after some troubleshooting respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | kawasaki KLX 300 Motorcycles
My 2002 honda cr 125 has no spark the stator plate had a break which was fixable, the coil was shredded when the plate broke so replaced it with a new one still no spark, bike been lying in garage for a...
check the ht wire ok , resistance on the plug cap not too much ! ignition coil wires etc ! place ht without cap or plug fitted against the head or in your hand if your brave and crank over to see if there is a spark ! ?? P...
Jun 29, 2011 | 2002 Honda CR 125 R
Apache rlx300 wont start spitting back through carb
check spark,timing from side case side,then swap spark plug,try to bypass spark cap,then check flow of petrol to carb,clean carb and allow to cool if needed.Sometimes a coil just dies for no apparent reason..The last resort is to swap the coil inside the side case...
Jul 26, 2009 | 2004 Factory bike Chrono SM 250
Quad bike wont start, just turns over
To check the spark put the spark plug in the cap and rest the tip of the spark plug on the head of the engine and crank it over. You should see a strong spark.
(Remember doing this creates electricity so don't touch the tip)
May 27, 2009 | RTO Mini Quads
RTO Mini Quads Logo
1,807 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
