Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not turn on. Unplugging the TV seems to reset this and allows me to turn the TV on briefly, then it shuts down again with the flashing light.
  • 50 Answers
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Posted on Feb 17, 2010
Need service manual for panasonic pt-50dl54j
You should be able to download a technical manual from this site.
Scroll down below the cover image and press on Download File link that shows up in about 10 seconds after opening the link.
PANASONIC CHASSIS GN1D PT 50DL54 PT 60DL54 DLP TECHNICAL GUIDE Service...
Aug 28, 2014 | Televison & Video
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I am about to replace a DLP lamp. How do I reset the lamp time on a Panasonic PT-50DL54J, using a TY-2004 lamp?
This all probably comes a couple years too late, but when you install a new lamp, you’ll want to reset the hours on the counter your television has. Doing this will allow you to avoid getting any messages about the lamp needing to be replaced despite you having a new lamp inside your set.
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jan 31, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic HDTV DLP PT-50DL54J does not power up, instead power light flashes red eight (8) times. No repair service near us in rural South Dakota. It will probably be necessary for me to repair myself,...
Hi to all Panasonic HDTV DLP PT-50LC13 owners i have this TV for Repair or Parts. It does,nt powerup i know the fix but i dont want it so is for parts for $100 bucks
Dec 05, 2009 | Panasonic Televison & Video
MY PANASONIC PT-50DL54J DLP will just turn off. I
I have posted solutions for similar problems.
There may be a heat issue with the power supply components.
Remove the back panel and blow compressed air into all the component area, (except the fan on the right). The power supply is on the left.
Then vacuum all the dust out.
There may be a problem with the battery in the remote. Weaken batteries can cause the remote to send random signals (including turning off the set).
Aug 22, 2009 | Panasonic PT-50DL54 50" Rear Projection...
How many times is it blinking? That is probably blinking a code because its shutting down. Let me know how many blinks its blinking and I will be able to tell you whats wrong with your TV
Apr 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
674 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
