Question about ASUS P5LD2 Motherboard
M/B will not see my IDE hard drive
Bios setup does not recognized any hard drive (IDE). Tried 3 different HD.
  • Anonymous Mar 21, 2014
    hd not recognized in bios
    Problem Solver:
You really don't have enough information here for anyone to offer any detailed answers. I have had problems in the past with the ribbon connectors being connected incorrectly to the wrong devices. I mean, if the connector can support 2 devices, make sure the correct plug (ends or middle) is connected to the motherboard (or device), in the proper orientation. Also on the hard drive, check to make sure that the jumper in back of the drive is set properly for master or slave device. If you have another device connected to the ribbon cable, one HAS to be a master, and the other HAS to be the slave drive. Finally, check through all your BIOS settings relating to the connected EIDE and ATAPI drives you are using, to make sure all the settings are where they should be. If you are not sure how they should be set, use the "Save with failsafe settings". This will reset the BIOS to the most basic, usable settings.
Posted on Jan 09, 2008
    Problem Solver:
  • 6 Answers
You ned to post also the model of your mother board, or computer
New 1tb hard drive not recognized in bios
it is like putting a new stereo in a totalled car,
May 29, 2015 | Hitachi Computers & Internet
Messed up an IDE partition now BIOS won't recognize drive, can this be fixed or is there a workaround?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? Hope this helps.
Dec 09, 2012 | Computers & Internet
This Emachine will not boot from HD or CD. The screen only says Emachine.
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Hello, I've got a WD 200BB IDE drive I'm trying to install in a Dell Optiplex GX620. Since there are no IDE controllers on the mobo, I'm using an "Ultra" SATA to IDE ATA adapter. I cannot get...
Go into the BIOS and hold down the key and then press the and keys in succession. This should force the motherbrd to go out and detect all connected devices.
Apr 10, 2011 | Dell OptiPlex GX620 PC Desktop
I have a compaq s5100nx desktop with a crashed 80 g ide hard drive.i am trying to replace it with a 500 g drive but the drive is not recognized by the bios i have tried 2 different drives already. However...
did you configured the Hard drive jumpers correctly?
Was the original HD set to master or Cable select?
if so please set your new hard drive to the same jumper settings as the old one.
Mar 19, 2011 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
Toshiba Laptop A60-S166 fdisk won't recognize hard disk? ACPI Bios Version = 1.40 Bios setting Drives I/O where it says Built in HD = No Drive Built-in ODD = Secodary IDE(170/IRQ15 Won't let me get into...
Hmmm. Unusual report, "secondary optical disk". Sounds like you have a primary and secondary IDE setup. Something desktops had, but rare for laptops. Because of this, I would try setting the HD to "master". Most IDE HDDs have some extra pins beside the IDE pins, 4 or 6 pins in a separate compartment, same side as IDE jack. These are for choosing "master", "slave", and (default) auto detect. To find out which pins must be connected, look for a diagram on the lable or side of HDD. If none there, look up the specs on your HDD at the manufacturer's website. If all fails, It does not hurt to use "trial and error" on these pins. Either BIOS will be happy, -or ignore the setting. Try again until you find the right one. You need a small jumper to try this. If you are VERY careful not to wrap more than two pins, you can do this with a single wire from a copper stranded wire. Use hemostats and clip the excess off clean. Use a magnifying glass to verify it only touches (connects) two pins.
Personally, I would try THIS first, but it will cost you a bit of money... Buy an external IDE HDD case, with USB connector, insert your HD, plug it into a desktop PC, mount it, and use FDISK there. Always better to format a 2.5 inch drive via ext methods. Avoids funky BIOS corruptions, wacky 8mb Toshiba "recovery partitions" and MBR viruses. Also avoids the LBA limits many older laptops have, if YOU format the drive externally. This can also be the only problem. Not jumpers, but format methods. If the laptop is older than 3 or 4 years, I would suggest restricting ALL partitions to FAT32. Maybe C, D and E. Afterwards, the external USB case is a GREAT device to have, for exporting/storing large files from your laptop.
Let me know how it goes
Feb 08, 2008 | Computers & Internet
Replaced Motherboard HELP
So the HD is not recognized at all or do you see it in the BIOS? If you don't see it at all then obvious things to check are the power cable, and the IDE or SATA cable. If it's an IDE drive it's not too difficult to bend a pin while attaching the connector. I would check that. I'm guessing you did not change any jumpers on the drive. Last thing I can think of is to be sure the BIOS settings are correct depending on if it's an IDE or SATA drive.
Nov 19, 2007 | Dell Dimension 8400 PC Desktop
ASUS P5LD2 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
