HDMI cables give no picture they say check signal cable
I had a problem with my tv but it was fixed by one of your experts -welcomejee. It can be found under generic problem for all Flat Panel Televisions ''I have a Samsung lns469dx-xaa. Basically I had no picture but only sound and had to replace my T-con/LCD controller board.
After I did this I plugged in the HDMI cable and got great picture and noticed it would come and go and I had to play with the cable in the back until I finally got it right.
I went to the store to pick up a shock protector for the tv and cable box and when I came back the hdmi cable did not give me any signal. It said check signal cable or no signal. I checked both ports but still no luck.
I called the cable company and they troubleshooted over the phone with me but still to no help with getting a picture through the cable. So the cable company sent over a tech to see if it was the cable box or my hdmi cable. The tech said the box was fine so it must be my hdmi cable. I can watch tv through the audio/video cables but why do that if you can watch it through hdmi cables.
So on Friday I went and bought a new cable and tried it out. Still the same thing. In both ports it says check signal cable or no signal. Can someone please help me so I can finally fix this tv once and for all.
Thanks,
Erik
  • 2 more comments
  • rdheb Nov 15, 2009
    To Rylee,
    Thank you for your prompt attention to my issue. I tried both of your suggestions but to still no avail. The tv was not in closed captioning mode. Let me tell you what I did to make sure I followed your instructions correctly.
    Since I could not access the closed captioning mode via the hdmi signal cable (because it was not an option that was highlighted since there was no program being broadcasted) I used the white, red, and yellow cables to go to AV 1 and was able to get a picture with sound. I checked to see if it was on the closed captioning mode and it was not.
    I tried the next suggestion you had. I ran the hdmi cable from the cable box (PVR- even though I don't have digital video recording as an option on it) then to the tv. I then muted the tv. I then ran the red, white, and yellow cables from the cable box to the tv. After that I still got nothing through the hdmi input when I switched to it from av1. It said checking for signals, no signal.
    I also noticed that nothing was picked up now through my hdmi 1 port but could only use my hdmi 2 port. Do not know why that is happening now. Please offer any other solutions if you have them or correct me if I did not follow your instructions to the t.
    Thank you,
    Erik
  • rdheb Nov 18, 2009
    To Rylee,
    I have a lot of questions for you so please be patient with me, thanks.
    Overview:
    I looked at the ports of the HDMI and saw that the HDMI 1 was loose. I was able to take it out and plug it back in. It looked like the soldering wore off. I took the whole board to a tv repair shop and the man who worked there told me they do not fix boards there. He told me if I wanted it to work again I would have to buy a new board but suggested I do not. He said the soldering was definitely off from the HDMI 1 source. He also asked what cable service I used and suggested after telling him what service I used to just use component cables and they would give me the same quality as the HDMI cable.
    Do you agree with the suggestion of component being the same quality as HDMI? (I was told you would really have to look close to tell the difference.)
    Question 2
    I just bought a PS3 with the blu-ray player. Will I be missing out on anything if I go component over HDMI?
    Question #3
    I saw that if you go 1080 P you should use HDMI for blu-ray. Can you tell with the model of the tv I have would I have to go HDMI?
    Questions #4 and #5
    I see that there is something called DVI out there. I see on the back of my tv that it says pc in but no DVI labeled component. So my question is if my HDMI is shot can I use the pc in cable for DVI and get a cable that is DVI to HDMI and get the same quality picture as if I was using HDMI to HDMI?
    Question #6
    I saw that you would want to use a more expensive (shielded cable) if your distance is long from your tv to your cable box/PS3. I have a distance of about 13 feet. My question is do I need to spend money on more expensive cables like monster or can I get away with a different less expensive brand?
    Questions #7 and #8
    The guy at the repair shop said that the HDMI port 1 connection looked fine it was just that it came loose. If i re-solder it any chance of me getting my HDMI back? What if I buy another HDMI port and resolder that to port 1 any chance of that getting the HDMI back?
    The thing is the whole board cost $260.00 and I am looking for a way around that. Also I am looking for the best quality I can get for the hardware I have. If there is not going to be that much difference then I can use the component cables over the HDMI cables but please steer me in the right direction. Thanks a lot and sorry for all the questions.
    Sincerely,
    Erik W. W.
  • rdheb Nov 19, 2009
    To Rylee,
    I know I sent you a lot of questions so I will be patient. Please let me know if you are working on them or do I need to send them in as another post?
    Thanks,
    Erik
  • rdheb Nov 20, 2009
    Rylee was very helpful and walked me through everything. I really appreciated Rylee's help. Thanks a million!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Due to two things that will cause the no signal message to come up are, no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the no signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily the digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 15, 2009
  • Rylee Smith
    Rylee Smith Nov 15, 2009
    You followed the instructions correctly, unfortunately the HDMI 1 port has gone faulty and the whole whole tuner board will need to be replaced. However, before replacing it you can make sure that HDMI port 1 internal connections are fine.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Nov 19, 2009
    Hi Erik
    Sorry for answering your
    questions so late due to my other pre-occupations. Answers to the questions are
    as under:-
    1.
    No. Because on some models component cable do much
    better than HDMI and vice versa.
    2.
    As mentioned above, please try both one by one and you’ll
    be able to see the difference.
    3.
    Same as above. But it is not certain.
    4.&5. Yeah, you are right.
    6.
    It will be useful and economical to choose and use less
    expensive brand.
    7.&8. Yeah, sure after re-soldering you’ll get the
    HDMI back.
    The gist of knowledge never ends.
    However, you’re going in the right direction and I hope this will resolve the
    issue you are facing with. You should not feel sorry. Rather it is my pleasure
    to keep the gist subsidized.
    Thanks
    Rylee
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
How do I hook up my blu ray to my floor model panasonic tv
You can use an HDMI cable if both your tv and Blu-ray player have that imput. That will give you the best picture and sound. Both video and audio are carried through the one cable. Next down in quality are Component cables. You may need to use these if your tv doesn't have an HDMI input. These 3 cables are red, blue and green. They will give you the picture but no sound. This is normal . All component cables need red and white composite cables for audio. When you have made your choice of HDMI or Component, click the input button on your tv remote and scroll down to either HDMI 2 or 3 or 4(if you used an HDMI cable) or choose "component" to allow the signal to come through. Make sure you at least have the blue-ray player on so that when you do see it on the screen, you'll know which input you chose to get it to come through. Remember, after watching your Blu-ray, remember to turn your input back to your cable setting so you can watch tv again
Dave
Jan 28, 2015 | Panasonic Televison & Video
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Computers & Internet
HDMI cable was removed when TV on standby and X-box off. It was then replaced and we now have a message. "No signal. Check connection" and nothing else. Please can you suggest a fix? Have checked...
Might some how got that HDMI input port shorted?Tries tv unplug and that HDMI cable input it into another HDMI port,replug tv back about an hour later.So the tv resetting itself back to factory setting.Tv on goto tv menu,goto tv PICTURE SETTING going down to do resetting.This should resetting the whole tv Tuner signal board.These steps,should help ur tv HDMI ports functions again.
Jan 21, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I...
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Mar 13, 2010 | Sanyo DP46849 46 in. HDTV
Getting picture lines across tv that keep scrolling down like old tv's used to do. HDMI connected to cable box. Cable box to tv works fine and dvd to receiver hdmi to tv works fine no picture problems. can...
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Dec 19, 2009 | Harman Multimedia AVR-254
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
