Question about Toys
Power driver seat is not moving from reclined position in a 2005 kia sorento
    Brigadier General:
  • 4,044 Answers
Can you release the back and lift it manually? This recline function is usually a manual function and the spring that assist in returning the seat back to the upright position can easily come off. If this is power assist, then you need to check your fuses, if they are good, then check the switches, if they are good the motor is at fault. If you are going to be checking switches you will need to do a lost of disassembly and reassembly so I recommend you get the Haynes repair manual on your vehicle from Auto Zone since it will have detailed instructions on how to do this.
Posted on Nov 15, 2009
How do i fix the drivers seat back on my 2003 kia sorento
If it's a power seat, it's most likely the switch, but possibly the motor. If it moves one direction only, I would say switch. Neither direction would suggest the motor.
Apr 29, 2017 | Kia Cars & Trucks
2005 Kia Sorento has spark but no fuel
have you check the ignition switch?
it some tiemes will give you a miss fire you can do that from the bottom of the driver seat and also replaced with out take appart the whole stearing column
Feb 21, 2014 | 2005 Kia Sorento
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
Feb 06, 2018 | Chevrolet Suburban Cars & Trucks
Power seat wont move Front to back, But the back of the seat will move
check if you have any upstickels under your seat. like coins, cigarett...empty beer can etc. :) maby give it a litle push when pushing the butten. good luck
Aug 29, 2009 | 2005 Kia Sorento
Where is the driver side power seat switch for a 2005 Kia Sorento
the drivers side 4 way electric seat switch is faulty..
it wont go forward,,tryiing to source a used one(thats working)
For a new one i,v been quoted over
Aug 15, 2009 | 2005 Kia Sorento
Driver Side Power Seat Problem
the switch is probably bad try replacing it
Oct 22, 2008 | 2005 Kia Sorento
Toys Logo
24 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
