There's a white glow line on the bottom and side edges
Buy a better brand television.
Some do it some dont! simple
Posted on Dec 08, 2009
Hi, I just purchased a 22inch 2233BW samsung monitor, the label on top "Syncmaster 2233" and right side "50000:1" is a little faded out, is this normal or it means it was used and repackaged? also the top...
I would return it for a New Model.
Ask to see a display model.
The unit should also have a build date on the tag as well.
Its your money. spend it your way. !
Sep 30, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
No heat
Check the glow ignitor. It is located on the bottom of the drum. You will need to remove the back panel. Then with a 5/16th wrench remove the glow ignitor look for a crack that is visible or you will see a white line all the way across one side of the glow.
Apr 18, 2009 | Dryers
Wii remote hit the tv, and it's cracked from inside.
Got insurance?
This is a claimable accident if you don't mention the WII controller that should have been used with the strap. Did you witness it was that controller? Could have been the vacuum cleaner. I don't think it is that controller, because is with a protecting rubber cover.
The TV should not be used anymore and repair costs will not be of interest.
Apr 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Door can't close on lg refrigerator
As you look straight at the white plastic square: Make sure the edge of the gasket is in place along the outer (in your case, left side) of the door. There is a metal spring near the white plastic square, and the end of that needs to be tucked into the groove of the door, not showing on the outside. Then, line up the white plastic square with the corresponding hole and use the palm of your hand to pop the gasket in, starting closer to the center of the door and working to the WP square area. (should only take about three hits.) Then, line up and snap on the long white plastic gasket retainer strip which runs from top to bottom along the inner edge of the gasket.
Mar 15, 2009 | LG LRFD21855 Stainless Steel French Door...
Line in my lc screen
A line from top to bottom or side to side is a dead or failed pixel sensor. There are hundreds of pixel sensors at the edges of the screen, when one fails it causes a line, the line can be red, blue, white, or black. Unfortunately, there is no way of repairing the line, other that replacing the screen.
Jul 29, 2008 | Compaq Presario 700 470024-192 Notebook
Why!!!
Jul 29, 2008 | Toshiba Satellite L15-S104 Notebook
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
