Question about Keurig B60 Coffee Maker
Reservoire replacement B60 - Keurig B60 Coffee Maker
    Sniper:
  • 67 Answers
I know of this great! site, it sells all kinds of keurig products including replacement parts give it a shot i hope it helps http://stores.ilikenew.com/-strse-21/kuerig-coffee-maker%2Ckeurig%2C-keurig/Detail.bok
Posted on Mar 17, 2011
    Champion:
  • 213 Answers
4 Suggested Answers
SOURCE: Where can I get a replacement water reservoir for
Called the manufacture and they are sending out a replacement reseroir no charge.
Great coffee maker and GREAT customer service.
Posted on Dec 14, 2009
cmccune04
  • 213 Answers
SOURCE: crack in water reservoir
No problem, Here ya go......
http://iwantsweetdeals.com/Keurig-B40-B60-Water-Reservoir-Tank--P1207341.aspx
Posted on Jun 14, 2010
  • 5 Answers
SOURCE: need a replacement cover for the water reservoir
Unfortunately, you may need to contact Keurig and order the cover.
Is the cover just cracked? Maybe you get get some non-toxic waterproof glue and repair.
Good luck.
Posted on Feb 04, 2011
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
My Keurig B60 just stays flashing "NOT READY". I can turn it off, I can't get the menu... nothing. I unplug it and it comes back on the same way.
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Feb 06, 2010 | Keurig B60 Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Keurig b60 not pumping water, just bubbles
Jan 21, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
501 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
