Question about HP DT PAVILION P6110f DESKTOP PC
I have a HP Pavilion p6110f Desktop, I want to connect two monitors to the PC, since there is only on Video output, I have to buy a new PCI Express video card. once I install the new video card, it seems the original integrated video card was disabled. how to fix it?
  • 28 Answers
You can either use the integrated OR the video card, CANNOT both at the same time.. You should buy a PCIe graphic card with dual output support.
Posted on Nov 15, 2009
Testimonial: "I got it."
What pci wireless do I need for a pavilion 6110f
Any of them should work just make sure you have 1 that works with your version of windows.
Apr 27, 2014 | HP DT PAVILION P6110f DESKTOP PC
I have a HP Pavilion p6110f Desktop with the video signal that goes in and out..
Buy a Graphic Card PCI e x16 compatible. Install, Move the monitor cable to the new card connection and your good to go, with better graphics. If you haven't installed a Graphics Card before, do a little research. Take a look at this for example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684404&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3970026
Dec 29, 2012 | HP DT PAVILION P6110f DESKTOP PC
Where is connection for hp pavilion p6110f to tv
Unless you have a dedicated video card (which is NOT included on the stock model of this PC, you'd have had to have added it after buying) there isn't one. Check your TV for a VGA connection (a blue connector, like your monitor) and if it doesn't have one, you're out of luck.
Sep 02, 2011 | HP DT PAVILION P6110f DESKTOP PC
Can i use two monitors with my hp pavilion a1340n desktop computer,it has windowx xp in it
With the factory provided hardware no. There are options like an external video card or purchasing an internal video card with two output interfaces. Your pavillion comes with an available PCI-Express slot for installations of this type of hardware and there are a lot of very affordable options like the Geforce GT420
Aug 17, 2011 | HP Pavilion a1340n (EL470AA) PC Desktop
HOW CAN I INSTALL A NVIDIA GEFORCE 7200GS ON A HP 500B DESKTOP PC. IT IS CONFLICTING WITH THE ON BOARD VGA, THIS IS PREVENTING ME FROM USING THE GEFORCE AS A SECONDARY DISPLAY WHICH THE REASON I BOUGHT IT
It appears that you have spent real time and money to upgrade your system.
I understand your problem. You want dual output VGA's to have two monitors setup with your system. The computer, HP500 has an onboard VGA out, and your add-on PCI express will not give you a second out VGA.
More than likely, HP / Compaq might not support this configuration with thier CMOS>
Maybe better soloution would be since you already have a VGA and DVI video outputs from your new PCI express board would be to go into BOIS and disable your onboard VGA. The VGA should then revert to the new PCI express board. You then could connect the second monitor to have both on the PCI express board. If you have only VGA (blue type) connectors, you can get a DVI to VGA adapter.
At Newegg online or Tiger Direct should have them if needed for less than &10, plus S&H.
Good Luck
Aug 13, 2011 | Nvidia GeForce 7200 Graphic Card
I need instructions on how to install a new Graphics card for my HP Pavilion a6600f. How do I go about doing it safely. I do not want to risk making a mistake. I will also be installing a new power...
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357119&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=ca&lang=en&product=3794742#N201
this motherboard:
  • Also supports PCI Express x16 graphics cards
  • Turn the computer off.
    Disconnect the AC power cord.
    Disconnect the "data" cord from the "on-board" video-card.
    Remove the side-panel.
    Buy a PCI-E video-card.
    Insert the video-card into the PCI-slot -- make sure that it is fully "seated".
    Connect the "data" cord from the monitor to the new video-card.
    Replace the side-panel.
    Reconnect the AC power-cord.
    Turn the computer on, and let Windows "discover" the new video-card, and load new device-drivers.
    Dec 20, 2010 | HP Pavilion a6600f Desktop PC
    I want to upgrade my video card. I know I need a separate video card but which one will give me the best performance to play games without the jerky screen? I did install 2gb of DDR2 ram with little...
    According to the specs of your motherboard it supports PCI Express x16 graphics cards.
    See HP Pavilion a1320n Support
    You can get a start by going to Tiger Direct and looking at their video card selections.
    Here's a link: Tiger Direct PCI Express Cards
    You can get several different memory amounts on the cards. I would probably stay with a minimum of 512MB.
    You need to watch the connections. If you use a VGA connector to your monitor, make sure the video card has one. Some only have HDMI or dual HDMI.
    Of course you can always find them at most Big Box stores such as Staples, etc.
    Ask questions. Make sure what you buy is compatible. Hope this helps.
    Thanks for using Fixya.
    NOTE: Keep in mind that smooth video is interdependent on RAM, CPU speed AND video card.
    Nov 17, 2010 | HP Pavilion a1320n (882780261747) PC...
    I have two HP w2408 lcd moniotors I want to connect to my HP Pavilion desk top. What do I need to do so that i can display separate documents on each screen?
    you going to need a good grafics card pci express interface whid 512 mb or ram and the apropriate drivers for it and afther you plug in the 2 monitors your pc will indentifie dual monitors and you can expan the desktop
    Oct 28, 2009 | HP Pavilion Desktop with Intel Pentium...
    Video card
    PCI Three (two available) PCI Express One (available) you can use a compatible pci or pci xpress video card to upgrade your system to a better video card check compatibility with yur media center PC.
    hope it helps..
    Jun 20, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
    HP DT PAVILION P6110f DESKTOP PC  Logo
    306 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
