Question about Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd
Backlight bulbs keep burning out - Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd
    Sergeant:
  • 297 Answers
First try to reset ur phone if it won't work then there might b a hardware problem...
Posted on Nov 15, 2009
TK 760H BACKLIGHT NOT WORKING HOW DO I FIX IT
This is common for these older radio to burn out light bulbs. Do a google search for the service manual, it will show you how to disassemble the rig and what bulbs you need, many of these mobiles are an absolute nightmare to replace the bulbs yourself
Sep 04, 2014 | Radio Communications
When the headlights are turned on, the clock/radio display cannot be seen. Would this be a fuse that needs to be replaced or a burned-out bulb, and, if it is a burned-out bulb, how do you go about...
I think the problem is in your dimmer switch. It controls the dash backlights as well as the display on the radio. Is this a factory radio and are you dash backlights bright?
Oct 17, 2013 | 2001 Nissan Sentra
Monitor getting dark
Your top backlight element is not working, probably burned out or has a wire that has become disconnected or burned off at the end of the bulb. You will need to replace the top bulb and or reconnect the soldered wire.
Apr 01, 2013 | HP w2207 Monitor
VIZIO REPLACEMENT PANEL
You are a brave man for taking apart your panel. It's most likely the bulb is failing. Failing CCFL bulbs draw more current when they age which could explain the melting holder. They also tend to give off a pinkish glow when they are at the end of their life cycle. I'm not one to guess, I like to verify before replacing. There are testers for CCFL but not worth investing the money for a one time deal. I usually keep the boards attached to the back of the panel. Remove the LCD panel and prism materials to expose the backlights. I then turn on the set and monitor the lamps, checking for any that are giving off a pinkish tint, The bulb could be your problem or just one of your problems. As I stated earlier, aging backlights draw more current than normal, this can cause failure in your inverter(s) boards.
Feb 05, 2013 | Vizio E470VLE 47 Class Widescreen LCD HDTV
When first started, the monitor screen is fine; however it dims shortly thereafter. Help
Unfortunately this might be a hardware issue. My old HP used to do this, and then the company finally accepted it back for repairs.
What happens is there are bulbs/ backlights that keep the computer screen lit. After aging, or even possibly damage, the light might be burning out.
If you send it for repair they can easily have this fixed, and provide you with a new backlight.
Hope this helps, and best of luck! :)
Mar 17, 2011 | Dell Computers & Internet
I turn my monitor on and it lights up then goes blank.
sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Aug 01, 2009 | HP w1907 LCD Monitor
Backlight is off
You either have a bad LCD or bad backlight board. The backlight on your screen is no different than a light bulb. If it burn out it stops working, if these is no power to the backlight your screen will have an image but no backlight to see the image.
Jul 03, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
Jun 09, 2009 | 2001 Mercedes-Benz C-Class
Lcd of my gateway laptop lost ligth inside so is to dark but i can see the destop icons but is to dark
Your Backlight bulb has burned out, or the Inverter for it.
1.General information on replacing a Backlight lamp,
(Bulb)
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2.General information on replacing an Inverter,
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
May 28, 2009 | Computers & Internet
Speedometer backlight not working
There are several bulbs on the back side of the cluster assembly. Sounds to me like you need to replace the one that burned out.
Sep 30, 2008 | 2002 Nissan Pathfinder
Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd Logo
81 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
