Question about Comfort-Aire BHD-501 Dehumidifier
Not accumulating water and condensation on top
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
Your unit is low on freon from a sealed system leak. The sealed system should have a 5 year warranty. You need an authorized LG tech to write it up for an exchange. Check your manual and call an LG service dealer.
Posted on Jan 23, 2010
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Sep 24, 2013 | Dehumidifiers
Hello :) There is a tube that is hanging out of the back of the dehumidifier... so I need this to operate it? Can I use without it?
is there an internal storage tank for that unit. It is probably the drain tube for condensate. Put it into a bucket, run it, and see it water accumulates. If so, that's what it is, and must be put into a bucket, that then must be emptied frequently.
Oct 07, 2010 | Maytag M7DH65B2A Dehumidifier
Removed Little Water
If on the top you mean only at the top of the cooling or condensing coil the machine could be low on refrigerant.
May 26, 2010 | LG LHD45EL Dehumidifier
Water on top of unit
There is no problem...in a damp environment the top will get cool and water will condensate on it also...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 12, 2010 | LG LHD45EL Dehumidifier
Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
Oct 06, 2009 | LG LHD45EL Dehumidifier
1995 Jeep grand cherokee limited. Have water
take the under panel from under you glove box out. You will see the fan box and the condenser. The drain hose is there too. Take the hose lose and blow it out... A Pc air can for blowing off key boards will work. Get it at Wal-Mart in electronics
Jul 26, 2009 | Dehumidifiers
Dehumidifier
Dear rmclpc
huuum at your service.
Here is a site offered by fixya.com for owners manuals.
http://www.pronto.com/user/search.do?displayQuery=
kenmore%20elite%20oasis%20owners%20manual&SEM=true&query=kenmore
%20elite%20oasis%20owners%20manual&adid=1210312579-6519660d_10_gc&ref=
owners%20manual&creativeid=1167763135&site=
www.fixya.com&loadingComplete=true
Bless You,
huuum
Please give me a good rating before you sign off here at fixya.com
Sep 17, 2008 | Maytag M7DH45B2A Dehumidifier
No Water
Check to see if the coils are cooling down. When the coils are cooling down, they make condensation on them, which is moisture from the air. This moisture drops down in to the tray. This is the water that is accumulated.
If the coils are not getting cold, this can be a problem with the workings of the cooling system. There are a number of hoses, pipes, the compressor, evaporator, and other parts involved that can have a problem. It is also possible that the gas has leaked out of the cooling system due to a leak that has formed.
If the compressor is not starting up, this can also be from a defective humidistat, or there is a fault contiditon that put it in to a protection mode.
Jerry G.
Jun 16, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
Comfort-Aire BHD-501 Dehumidifier Logo
124 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
J.D. Browning
J.D. Browning
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
