Question about Fuji FinePix 6800 Zoom Digital Camera
When shutoff, the lens dont retracts properly
Stripped gear is drive system is most frequent cause
Posted on Feb 16, 2010
Lense doesn't retract
Common faults for this:
The lens motor is defective, lens gears jammed. Fix is lens unit replacement.
The lens servo drive circuit is not functioning. Fix is to replace the circuit board that contains the lens servo control circuits.
The connector assembly between the lens is not making proper contact, or the lens wire assembly is defective. Fix is replacement of the cable and connectors if applicable in the particular model. If the connectors on the circuit board or lens are defective, then the appropriate unit must be replaced.
No power is going to the lens unit, and or the lens servo circuit. Fix is replacement of the drive circuit board, or the power inverter if it uses a separate feed for the lens only.
Generally, with these low cost cameras they generally do not pay to service out of warranty. The service cost can approach the cost of replacing the camera.
Common causes of failures in these cameras is from water (getting wet), or dropping, or rough usage.
Jerry G.
Jun 29, 2012 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
When cutting on my camera, it saids lens error. i dont know what to do...
This error occured when lens is prevented from properly extending or retracting. When pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed due External shock or liquid, sand & dirt etc. enters the camera.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting.
2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Apr 12, 2010 | General Electric A735 Digital Camera
Lens stuck out
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 22, 2010 | Casio Exilim EX-Z77 Digital Camera
Lens will not retract lens error 20e,1,0,0
Put in fresh batteries in your camera and try to power on. If this didn't work, do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Jan 06, 2010 | Kodak EasyShare C613 Digital Camera
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
Oct 01, 2008 | Gateway DC-M42 Digital Camera
Lens wont retract, view lens blurry
Lens motor or lens servo amp is not working properly. Factory service is require. They will replace the circuit boards and or assemblies as required.
Jerry G.
Jul 11, 2008 | Kodak EasyShare V1003 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Pentax E10 will not power up ( w/ fresh batteries) !!
hi. me again. flicked the gray lens thing sticking out hard enough with my finger as i got pissy with it and WALLA! it works now. just thought id let you know.
Apr 09, 2007 | Pentax Optio E10 Digital Camera
Fuji FinePix 6800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
